Oil leak
Old Jun 16, 2008 | 07:19 PM
ajw65's Avatar
ajw65
3rd Gear
Default Oil leak
Riding my bike after 60 miles I noticed oil on my chaps on the right thigh close to the oil tank. Also on the tank I noticed oil. The cap is on right and this is the only place I see oil on the bike. This is on a 2006 1200c. 3000 miles last oil change was at the dealers. Any ideas?
Old Jun 16, 2008 | 07:26 PM
SpursDarkrider's Avatar
SpursDarkrider
Default RE: Oil leak
running too much oil in the tank?
Old Jun 16, 2008 | 07:36 PM
ajw65's Avatar
ajw65
3rd Gear
That was my first thought I just had the oil changed at the steelers a month ago. It seems to be at the top end of the full mark when full. Right on the line.
Old Jun 16, 2008 | 07:54 PM
SpursDarkrider
the top line? the full line?
Old Jun 16, 2008 | 07:55 PM
SpursDarkrider
if its completely up to the full line, it has way to much oil in it. get a turkey baster and siphon out 8 ounces
Old Jun 16, 2008 | 07:56 PM
ajw65's Avatar
ajw65
3rd Gear
Wil do thanks.
Old Jun 16, 2008 | 07:59 PM
SpursDarkrider
the stupid stealer should know better than to fill a bike completely up
Old Jun 16, 2008 | 08:00 PM
DPete's Avatar
DPete
If that doesn't work put a new o ring on the dipstick
Old Jun 16, 2008 | 10:04 PM
BluePotato's Avatar
BluePotato
The service manual states that you need 3.6 quarts of oil in the tank, but that's too much and Harley has changed the recommendation to 2.8 or so (3.0 at the absolute max). I had the same problem. Also, I had oil coming out of my breather and they had to install a new rocker box (they installed an '07 rocker box on my '06). No problems since.
Old Jun 23, 2008 | 03:27 AM
ajw65's Avatar
ajw65
3rd Gear
Sorrry I haven't responded back sooner. It appears as if it was to much oil, I removed about 7 oz out and took a good run with no leaks. Thanks for the help..
