Chug, chug, chug????
2nd gear to 40mph
3rd gear to 60mph
4th gear to 75mph
5th gear to 125mph
Anything less than that and your are pu**y! \\; Oh and thats 2-up!!
Around town it's a 1 down and 3 up bike. Never hit 5th till I'm out on the highway.
1st gear to 20mph
2nd gear to 40mph
3rd gear to 60mph
4th gear to 75mph
5th gear to 125mph
Anything less than that and your are pu**y! \\;\\\\\\; Oh and thats 2-up!!
2-5/8" Mini Tach Kit with Shift Light - Black Face
Now available with an attention-grabbing rider-selectable shift light, these chrome-plated, 0-8,000 RPM mini tachometers add style and function. Measuring 2-5/8 inches in diameter, these chrome-plated tachs boast superior illumination and high-quality construction. The hard-coated lens is both fog and scratch-resistant and is ultrasonically welded to the case, resulting in a strong, reliable seal. These tach kits deliver impressive accuracy and response. Our exclusive, balanced pointer design allows for a quick, precise needle sweep and minimal low idle flutter. Plus, reverse polarity and over-voltage protection ensures these quality tachs are immune to voltage surges, low-voltage interference and ignition coil inductive kick-back. Tested to the highest industry standards, each kit is specifically designed for each model, with styling that matches current speedometer graphics, including a lighted pointer. Complete wiring, hardware, and installation instructions are included.
69829-06
Fits '96-'03 and '07-later XL Custom, '96-later FXDWG, '06 FXD35, '07-later FXDC, '84-later FX SoftailÂŽ (except '07-later FXSTC), '86-later FL SoftailÂŽ (except '07-later FLSTF), and '94-later Road KingÂŽ models equipped with Mini Tach Mounting Bracket. Separate purchase of application specific Mounting Bracket and Gauge Housing is required. \\;
MSRP US $149.95
4" Combination Speedometer/Tachometer - Color-Matched Lighting
Now available for 4" Speedometer applications. This unique Combination Speedometer/Tachometer allows you to monitor engine speed without adding a handlebar-mounted tach. The unit mounts in the stock 4" gauge opening and is a direct plug-in installation. Utilizing the trip reset push button, the multi-color LED lighting system allows the rider to adjust the backlighting of the gauge to the color of choice. With over 600 color tone options, the gauge lighting can be matched to any paint scheme or viewing preference. The gauge features an easy-to-read LCD odometer/tripmeter. Mileage reinstatement is available through your dealer.
This product is available in multiple variations. Be sure to look for the one that fits the specific model and year of your motorcycle.
74726-08
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
Fits '07-later XL models. '07 models require separate purchase of Resistor Pack P/N 72545-08. \\;
MSRP US $499.95
1st gear to 20mph
2nd gear to 40mph
3rd gear to 60mph
4th gear to 75mph
5th gear to 125mph
Anything less than that and your are pu**y! \\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\; Oh and thats 2-up!!
LOL welcome back a**hole!
 \\;\\\\\\; I would've posted my 1-up numbers but you would've got on me for showin off.
69829-06
Fits '96-'03 and '07-later XL Custom, '96-later FXDWG, '06 FXD35, '07-later FXDC, '84-later FX SoftailÂŽ (except '07-later FXSTC), '86-later FL SoftailÂŽ (except '07-later FLSTF), and '94-later Road KingÂŽ models equipped with Mini Tach Mounting Bracket. Separate purchase of application specific Mounting Bracket and Gauge Housing is required. \\;\\\\\\;
MSRP US $149.95
74726-08
Fits '07-later XL models. '07 models require separate purchase of Resistor Pack P/N 72545-08. \\;\\\\\\;
MSRP US $499.95
For 49.95 Ill ride around next to you and YELL at you when to shift.. \\; Thats a huge savings depending on how you look at it.
