electrical causing back fires ??
Old Jul 19, 2008 | 10:07 AM
DEG's Avatar
DEG
Stage II
Default electrical causing back fires ??
&nbsp\\;got a misfire in rear cylinder&nbsp\\; and occasional back fire out tail pipe,
was wondering ,&nbsp\\; is it possible that it's being caused by low battery voltage / bad alternator ?
missfire seems to be happening at any speed ... 1990 883 hugger.
Old Jul 19, 2008 | 01:43 PM
HOTLAP's Avatar
HOTLAP
Default RE: electrical causing back fires ??
If it was low voltage I dont think it would do it only on the rear cylinder, check the voltage it should be about 14.5 volts a little above idle. Otherwise install new plugs, check the wire for arcing, other than that it could be a bad coil or vacumme leak on rear intake, test that with WD 40 sprayed around the intake while engine is idleing.
d-streetglidr
Jun 13, 2013 11:41 PM
im
Jul 27, 2012 12:52 PM
deleontow
Jul 12, 2008 10:37 AM
CAGE
Exhaust System Topics
Dec 30, 2007 05:08 PM
doakley2
Dec 19, 2006 10:13 AM
