Nightster Reflectors
Old Aug 9, 2008 | 08:35 PM
coze's Avatar
coze
Default reflectors
Took mine off today ,love the look.wd-40 and floss.
Old Aug 9, 2008 | 10:10 PM
confederate's Avatar
confederate
Most Wanted
Heat them up with a hair dryer and you should be able to pull them off without using any tools. I also agree with the goo off. Works great.
Old Aug 9, 2008 | 10:21 PM
jag1886's Avatar
jag1886
If you just set it out in the sun for a while they will pull off by hand and the little bit of sticky crap that is left will mostly roll off off and use a little WD to finish. Dental floss will definatly not remove them.
Old Aug 9, 2008 | 10:45 PM
sbergloff's Avatar
sbergloff
Dental floss wasn't working for me, just kept breaking. I put a stronger cloth behind it, and just pulled on it and it broke right off. Goo gone worked great though for getting the adhesive off.
Old Aug 9, 2008 | 10:49 PM
denimnightster's Avatar
denimnightster
now here is a good question how do you remove the red reflectors on each side of the rear fender???? i really dont think its possible but maybe i am just missing something while looking at it.
Old Aug 10, 2008 | 10:08 AM
sbergloff's Avatar
sbergloff
I just left those on there. They aren't really that noticeable.
Old Aug 10, 2008 | 11:25 AM
OldFenderGuy's Avatar
OldFenderGuy
I've removed many of the rear fender reflectors, and it's no different that the front tube reflectors.
Leave the bike out in the sun for a while, use fishing line, and finish off with WD40.
Not a big deal at all.
Old Aug 10, 2008 | 11:38 AM
PigInaBlanket's Avatar
PigInaBlanket
I took mine off the forks and fenders by using a hair dryer to heat them up and pull them off then used Motsenbockers Lift Off spray to remove the left over adhesive. Worked like a charm.
I also used the Lift Off spray yesterday to remove some tar that stuck to my boot from the street then got all over my foot pegs. Came right off.
Old Aug 10, 2008 | 01:43 PM
BIGschwerm's Avatar
BIGschwerm
Im going to remove mine as soon as the ole knee heals up...
Old Aug 14, 2008 | 10:25 AM
bmxatv's Avatar
bmxatv
place where i got mine inspected said he wouldn't pass it without the reflectors on there. so i saved them and i'll put a piece of 2 sided tape on there at inspection time.
