Adjusting rear stock shock
Old Aug 24, 2008 | 06:07 AM
WVleo's Avatar
WVleo
Default Adjusting rear stock shock
Ok, besides the fact that My wife thinks I'm " DYsplEXic ( duh.....) " I look at the rear shocks on My 2006 1200 C and draw blanks.........? I have a Clymer's manual, H-D $10 shock wrench and stock shocks. Last bike started out with number increments, there lies the problem. If I go to the upper notches does it make the ride softer ? Any tips / help ? Bike is running fine for Me 5'5" 185lbs. 1 up almost always , but there is a place for the 115 lb wife on back. Just want to fine tune it a little. Replaced the last ride with Progressive 440 , might go with the 412's on this 1, but in the mean time.........WVleo
Old Aug 24, 2008 | 06:43 AM
Flatlander's Avatar
Flatlander
If you look at em like steps, the lower down on the step you are the firmer the ride as it compresses the spring on the shock. Hope that made sense.
1200Cdriver's Avatar
1200Cdriver
Leo, when the adjusting ring climbs up toward the spring it stiffens the ride. The high notches are softer. No matter where you set the stockers they're still back breakers. The stockers I had do their best work on a shelf about 20 feet from my bike.
One more thing Leo, that wrench will slip and bust your knuckles big time if you don't hold it onto the shock with your free hand. It slips out of the little notches very easily.
Old Aug 24, 2008 | 07:00 AM
SpursDarkrider's Avatar
SpursDarkrider
That shock adjustment tool is the worst POS i have ever paid my good hard earned money on.Channel lock pliers and A good shop towel works best.
Old Aug 24, 2008 | 07:12 AM
1200Cdriver
Absolutely, they stamp it out and the little nub that engages the notch in the shock is rounded instead of square. Makes for a hard to use tool.
Old Aug 24, 2008 | 07:13 AM
WVleo's Avatar
WVleo
Thanks ! Using 3rd notch from the bottom now. Seems about right for My needs ? And yes being stockers it is probally as good as it's going to get. .WVleo
see22ds
Jul 9, 2013 02:58 PM
Dissociative
May 5, 2011 10:31 PM
99Sportster
Oct 26, 2010 06:49 AM
fireman031967
Sep 22, 2008 06:41 AM
campdreamer47
Jun 8, 2006 11:07 PM
