SE ign module
Old Mar 23, 2006 | 08:49 PM
cootertwo's Avatar
cootertwo
Default SE ign module
OK, has anybody tried the SE ignition module in their 06 883? I got model#31784-04A Plugged it in, and now you have to go through a password learning bunch of crap. My unit does not seem to be doing what the directions say it's supposed to do. "HELP"
Old Mar 25, 2006 | 08:25 AM
cootertwo's Avatar
cootertwo
Default RE: SE ign module
OK, for those of you that might try to install a different ignition module in your Sportster, YOU DO have to go through a setup to get the computer "brain" to load up the "new" ignition module. The included instructions that came along with my Screaming Eagle module # 31784-04A, and all of the forum information I could find, state a series of on and off with the key, pressing the left turn signal twice, etc. etc. (LISTED BELOW) On my setup, nothing acted as the instructions said they would act. I finally followed the steps, but here's the thing, DISREGUARD THE 10 MINUTE CYCLE AND WAITING FOR THE LIGHTS TO GO OFF OR ON ETC. FOLLOW THE STEPS, BUT FOR EACH 10 MINUTE CYCLE, WAIT 15 OR 20 MINUTES, go watch some TV or bang the ole lady. Then do the off and on thing, and wait another 15 or 20 or so, and after three of these cycles, then do the off/on, wait about 10 seconds, turn it off, wait about a minute, turn it back on,and it should be done. It is a real P.I.T.A. Harley is going to loose their *** if they don't change their ways. "MARK MY WORDS" The days of throwing a screwdriver, pair of pliers, a spark plug wrench and a plug or two, in your little leather thingie, and taking off for a cross country trip, are over, unless you like sitting on the side of the road waiting/hopeing that a wrecker shows up to take you to the nearest authorized "Stealership"[8D]
TSM/TSSM ECM Password Learn Procedure
Step Action Confirmation Notes
1 Set Run switch to Run
2 Turn Ignition key On-Off-On-
Off-On-Off-On and then toggle
the Left Turn Signal switch
twice.
3 Turn Ignition key Off-On Verify the Check Engine lamp
and Security Lamp illuminate
briefly and then turn off.
Security lamp will not
illuminate on non-security
(TSM) Twin Cam models.
4 Attempt normal start one time. Engine starts and stalls
immediately. check engine
lamp stays on.
Password has not been
learned and sets trouble code
P1009, thus stopping fuel
flow.
5 Wait 10 seconds Security Lamp remains lit for
V-Rod and TC88 with TSSM.
Lamp will not be on for TC88
TSM models.
ECM enters Password
Learning mode for 10
minutes. Do Not cycle the
ignition or disrupt power.
6 Wait until Security Lamp turns
off or a minimum of 10 minutes
has passed.
7 Quickly (within 2 seconds) turn
Ignition key OFF-ON
TSM models.
8 Wait until Security Lamp turns
has passed.
Password Learning mode for
10 minutes. Do Not cycle the
9 Quickly (within 2 seconds) turn
Ignition key OFF-ON
TSM models.
10 Wait until Security Lamp turns
has passed.
11 Quickly (within 2 seconds) turn
Ignition key OFF-ON
Security Lamp light and then
turn off. Lamp will not be on
for TC88 TSM models.
12 Turn Ignition switch OFF. Wait
15 seconds. Turn Ignition
switch ON and start engine to
confirm the Password Learn
Procedure is successful.
Engine will start and remain
running. If engine immediately
stalls and fails to restart the
was not successful. Start over
at step 1.
The above steps must be timed and performed exactly as described. Any deviation will
require you to start again from step 1.
Old Mar 26, 2006 | 07:12 PM
francos's Avatar
francos
wow thanks for the ÄąnformatÄąon , Äą receÄąved my new module a mont ago but nobody was able to Äąnstall Äąt . Äą dÄąd exactly what u wrÄąted and BINGO now Äąt works .
Thanks agaÄąn
XL 883 C 2005
Old Mar 26, 2006 | 09:03 PM
cootertwo's Avatar
cootertwo
No problem. Another success without the help of a "stealership" [8D]
NCCopBikeRider
27
Jun 8, 2024 01:18 PM
big98
Apr 3, 2020 02:44 PM
steelerdude1
Dec 24, 2018 07:34 PM
tacarpe
Feb 18, 2013 08:46 AM
Sporty883Low
Jan 18, 2007 11:00 AM
