shutter
Old Mar 29, 2006 | 01:25 AM
molsenice's Avatar
molsenice
Default shutter
Well after discovering the rear brake pedal was tapping the front exhaust, I oosen upa few things, and it seemed to go away - well tonight it is back - only on deceleration-seams like something is tapping but no suspects -I just hope it isnt inside the trannie - feels like it is chucking on decel - like teeth arnt meshing - but it was a simple tapping before- will look closer tomoorow - I said frig it and rode it - any ideas?
Old Mar 29, 2006 | 11:04 AM
JohnK/Pa's Avatar
JohnK/Pa
Default RE: shutter
If it seems like the same noise you had before and your decelerating by down shifting, it could be the same problem, try slowing without downshifting or pull the clutch in when you hear the noise and see if it goes away, it could be the motors moving. If it sounds like a hammer inside the case, that's different.
Old Mar 29, 2006 | 03:07 PM
ronn39's Avatar
ronn39
Default RE: shutter
That's weird, molsenice. Might it be a loose baffle in the muffler?
Old Mar 29, 2006 | 04:18 PM
Rhubarb's Avatar
Rhubarb
Default RE: shutter
Maybe a loose/broken motor mount?
Old Mar 29, 2006 | 05:02 PM
molsenice's Avatar
molsenice
Default RE: shutter
I've been lookin - before it was without a doubt the front exhaust tapping the lower part of the rear brake pedal - feels like the same tapping shudder but now it seems more pronounced and there is no tapping - going to keep looking
Old Mar 29, 2006 | 05:10 PM
lschultz's Avatar
lschultz
Default RE: shutter
My sons was doing something similar to this on his XL1200C after he installed the V&H Straighshots he just had to reposition the pipe some and it cured it. I think his problem was more with using the rear brake he would feel the pedal hit the heat sheild.
Old Mar 30, 2006 | 05:31 AM
D1LD's Avatar
D1LD
Default RE: shutter
had a similar thing on my bike and it turned out to be the horn the 2 screws were out and the horn was loose so at differant speeds and wind conditions it was vibrating and made all kids of bad noises found that out washing it for the first time since i bought it 6 months ago they had it detailed i think any way look and see if the horn is loose That might be the reason the guy was selling it
mtx1
May 7, 2019 04:53 PM
98wideglide95632
Jul 17, 2011 09:38 AM
Bad Daddy
Apr 19, 2009 09:56 AM
wbusch
Jul 23, 2006 12:17 PM
Peter Adley
May 17, 2006 01:43 AM
