how hard is it to install SE heavy breather?
Old Oct 28, 2008 | 06:38 PM
papadop88's Avatar
papadop88
Originally Posted by notfried
so easy a caveman could do it...or so i hear
Not Funny
Old Oct 28, 2008 | 10:55 PM
jbg's Avatar
jbg
What better performance will you get from installing a heavy breather over your stage 1?
Old Feb 16, 2009 | 09:00 AM
scrunchee's Avatar
scrunchee
Do you need any special tools when installing the SE Heavy Breather? I haven't worked on a bike myself and am a little nervous doing it.
Old Feb 16, 2009 | 09:04 AM
JayStronghawk's Avatar
JayStronghawk
Is a piece of cake that simple ... just take s a few basic tools if don't have a set of socket allen wrenches and Torque wrenches shouldn't be working on a Bike anyway...
Old Feb 16, 2009 | 09:45 AM
rdss's Avatar
rdss
Jay is right, a socket for the breather bolts, a set of allen wrench and a torque wrench. It will take you longer to pull off the stocker than it will take to install the Heavy Breather.
Old Feb 16, 2009 | 10:39 AM
tumbleweed883's Avatar
tumbleweed883
Originally Posted by JosephGarcia
well your gunna need to jack up the bike remove both wheels and the rear fender, pull off the rear cylinder of the engine and move the gas tank up 6 inches while simultaneously juggling the wheels you removed, and then reinstall the wheels backwards and swapped, and finally place the rear fender over the front fender and remove the handlebars.
it should take about 20 minutes if your in a hurry
edit: hopeuflly you realize im joking about everything except the 20 minutes part. its a simple job, just look at the instructions and youll know if its something you can do.
Speaking of air cleaners...Where is yours? I may be blind but I sure dont see it. You must have followed your own directions. You will note that your directions never say to install the breather!
Old Feb 16, 2009 | 02:51 PM
Threehouse1200N's Avatar
Threehouse1200N
Easy as pie! I just installed mine last week. Just take your time and its pretty self explanatory. Good luck!
Old Feb 16, 2009 | 05:41 PM
Firebird1989's Avatar
Firebird1989
Its really easy to do yourself, has pics of each part, and you shouldnt need the remap either mine runs great even w/ stock map.
Old Feb 16, 2009 | 05:52 PM
ramnj's Avatar
ramnj
It is pretty easy to install but I doubt that the regular Stage 1 update will be enough to compensate for the amount of air you'll be sucking in.
Old Feb 17, 2009 | 02:12 AM
plasmadaddy's Avatar
plasmadaddy
Did mine last night - took me 30 minutes, real simple job
