nightster handlebar ?????
Old Dec 17, 2008 | 08:58 PM
oldskool4life's Avatar
oldskool4life
Default nightster handlebar ?????
i am swapping out the stock bars for a set off drag bars and on the factory bars there is a indention where the wires lay passing thru the front brake. the aftermarket bars dont have this indention how do i get around this. please help thanx
Old Dec 18, 2008 | 06:48 AM
Gpsjr10's Avatar
Gpsjr10
You can do one of two things. Drill holes in the bar in the center on the bottom under the clamp and under both switch housings and run the wires internally, or drill an elongated hole in the bar long enough to get the wire into the switch housing from the outside. (just make sure you deburr the sharp edges from the holes.)
Bertk
2014-2024 Touring Models
206
Jun 9, 2020 05:14 PM
8ntsane
EVO
Sep 17, 2014 11:13 PM
dbuzzell
Apr 27, 2013 09:22 PM
volatile77
Electrical/Lighting/Alarm
Oct 31, 2010 12:53 PM
Threehouse1200N
Jan 29, 2009 03:03 PM
