RISER SWAP?
Old Apr 12, 2006 | 01:39 AM
hdxl1200's Avatar
hdxl1200
Default RISER SWAP?
[sm=helpout.gif]Has anyone changed the riser on their sportster?? I have an 05 1200 and was thinking of going with a different riser. Probably going to do mini-apes. Does anyone know if it is possible to use the stright riser that was on the pre-04(?) b/c I think that one should fit..right? Anyways this will be my first bar swap, so any help/info or advice will be appreciated. Would love to see some pics of other swaps as well. Thanks in-advance![sm=partyparty.gif]
Old Apr 12, 2006 | 02:16 AM
mikeisglidn's Avatar
mikeisglidn
Default RE: RISER SWAP?
my local shop did it, used the eariler risers and it worked out fine.
Old Apr 12, 2006 | 02:27 AM
boom215's Avatar
boom215
when they changed the riser what did you do with the speedo? cause on mine it looks it all goes together? unless you can just mount it someone where else?
Old Apr 13, 2006 | 12:59 AM
mikeisglidn
if i remember correctlly they used the mount off the 04 on the o5 ill check tomorrow and try to give you a solid answer.
Old Apr 13, 2006 | 01:05 AM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
We were going to do that to HC's 05 1200c but, could not figure out what to do with the wiring hidden in the riser...........did not want to rewire, keep us posted
r0880
Nov 30, 2019 08:42 PM
Bob Gnarly
General Topics/Tech Tips
Feb 22, 2018 08:42 AM
blacksmith_wills
Jul 6, 2010 11:25 PM
Shark46
Oct 22, 2008 02:09 PM
RA51
Feb 3, 2008 06:04 PM
