Rear Wheel Alignment
Old Mar 16, 2009 | 06:52 PM
dmschmidt's Avatar
dmschmidt
Default Rear Wheel Alignment
Dudes, I need some help! If I line up my rear axel to the swing arm, my belt hugs the outboard side of the rear pulley. If I adjust it so that it rides more to the middle of the pulley it pulls to the left when riding. What do you guys think? Should I not care where the belt rides, or live with the pull? Even with it parallel with the swingarm pivot it still pulls a bit.
Old Mar 16, 2009 | 07:18 PM
cHarley's Avatar
cHarley
It's perfectly normal for the belt to run "lightly" against the outside edge of the pulley when the wheel is spun in the forward direction. If you spin the wheel backwards you will probably see the belt move away from the outside edge.
Situation Normal.....
Old Mar 17, 2009 | 07:13 AM
WVHogRider's Avatar
WVHogRider
As cHalery stated, it's normal for the belt to rub the sides, just not excessively. You definitely want the tire running straight.
Old Mar 17, 2009 | 07:39 AM
FastHoss's Avatar
FastHoss
Just follow the procedure in the manuel,it's pretty easy.With the light belt tension involved a little rubbing is nothing,when you get into the 450 to 550 lb tension on the belt,it is a different game.
Old Mar 17, 2009 | 06:28 PM
dmschmidt's Avatar
dmschmidt
Thanks for the input, just seemed like it should run in the middle, 1st belt drive bike.
boise nightrain
Jul 2, 2018 07:43 AM
Spec36
Apr 2, 2018 07:11 PM
Rynb15
EVO
16
Apr 9, 2012 11:20 AM
busterman2
EVO
Aug 17, 2011 02:17 PM
Doug S
Jun 12, 2009 11:13 AM
