2up
Old Mar 19, 2009 | 09:39 AM
mississippiboy's Avatar
mississippiboy
Default 2up
couple weekends ago finnally got the ball and chain to hop on the back. she has never ridin and i have never ridin two up. Well it was a walk in the park everything was great. But i did notice my bike seem to ride better? it seemed to turn into twisties better and just all out felt alittle better. Is this a weight issue or did i just enjoy big ***** on my back but really i seemed alittle smoother!
Old Mar 19, 2009 | 09:42 AM
Dyflam's Avatar
Dyflam
Could be that the extra weight was right for your shock settings. You might need to readjust for solo. Of course you can't rule out the boob factor.
Old Mar 19, 2009 | 09:45 AM
mississippiboy
well they are lowered proggessive shocks. i have them adjusted as high as possible you think i need to come down some??? once i get alittle $$$$ im going to get much higher shocks cant stand the lowered ones
Old Mar 19, 2009 | 10:15 AM
wilburz's Avatar
wilburz
In order to answer your question accurately and completely we need to see exactly what you mean when you say 'big ***** on back'.
Old Mar 19, 2009 | 11:02 AM
Sick1200's Avatar
Sick1200
It's the ***** Now just buy the viberider and her legs won't let you go.
Old Mar 19, 2009 | 11:34 AM
mbwannabe1's Avatar
mbwannabe1
Your preload is probably set too stiff for your weight. Get a tape measure and see how far the bike moves down when you put your weight on it. You want about 3/4" of sag, so when you go over a dip or across an uneven expansion joint in the road, the springs can push the rear wheel down to maintain contact with the road. If the shocks are already fully extended when you hit the dip, you have to wait for gravity to pull the whole bike down before your rear tire is on the road again.
Old Mar 19, 2009 | 11:42 AM
mississippiboy
3/4" of sag with 2up also?
Old Mar 19, 2009 | 11:52 AM
BiggDogg's Avatar
BiggDogg
agreed with the *****
Old Mar 19, 2009 | 12:11 PM
WVHogRider's Avatar
WVHogRider
I have to agree that you probably need to turn your shock setting down when riding solo. I also agree with current set up for the ride....the boob factor/proper weight 2-Up for current shock setting. Now where's the pics of your back *****...
Old Mar 19, 2009 | 01:29 PM
Alex_C's Avatar
Alex_C
Yah probably shock settings, but also, I'm not gonna diss the boob factor. Since she was finally on there with you, your sense were turned up more acutely and you were really keyed up to do your best. In sports psych terms, you raised your excitation level to the optimum for the activity :-D
