Dealer says its normal
Old Apr 29, 2006 | 03:42 PM
30jim's Avatar
30jim
6th Gear
Default Dealer says its normal
I have an 05 1200 custom, on which I installed Vance and Hines straightshot slip-ons, rejetted and also added the high flow air cleaner. The problem I think I'm having is the bottom side of my rear heat shield is bluing and after riding for a little bit it seems to backfire once I let off the throttle. I stopped in and asked the dealer about this and they told me the bluing sounds normal with that pipe and the same for the backfire. Any suggestions? Thanks
Old Apr 29, 2006 | 04:02 PM
mthomas000's Avatar
mthomas000
Default RE: Dealer says its normal
Sounds like you're running lean and the dealer is making too much money off other people to bother with you.
Who did the initial re-jet?
Cheers,
Mark
Old Apr 29, 2006 | 04:19 PM
Thumper26's Avatar
Thumper26
I agree, you're running too lean. Sounds like a larger jet is in order. What size jets are you currently running and which "high flow" AC do you have installed?
Thumper26
Old Apr 29, 2006 | 04:24 PM
ronn39's Avatar
ronn39
Seems like "that's normal" are the only two words in dealer vocabulary. Blueing of the exhaust pipes is common and expected, but blueing of the heat shield is not "normal."
Old Apr 30, 2006 | 10:25 AM
cootertwo's Avatar
cootertwo
Sorry to keep bitchin, but here's another story of how Harley is going straight to hell. Seems once the stealerships get your name on the dotted line, and you're out the door, they are done with you, unless you want to venture back in with an open wallet, to get the shaft AGAIN.[:@]
Old Apr 30, 2006 | 06:22 PM
Black Katalyst's Avatar
Black Katalyst
Yeah, your back firing is cause by a lean air/fuel mixture. Try larger jets and see how its running.
The blueing of heat shields isn't normal. Are they too close to the pipes?
Old May 2, 2006 | 12:00 AM
30jim's Avatar
30jim
6th Gear
The dealer did the initial re-jet and I'm not sure what exactly I have in it. It has the S/E air cleaner. I appreciate your help.
Old May 2, 2006 | 12:33 AM
Johnny's Avatar
Johnny
The dealer says everything is 'Normal' it's a ready made responce used as often as possible
Old May 2, 2006 | 03:10 AM
skullcrusher's Avatar
skullcrusher
I have the same set up as you with straight-shot slip ons, and SE a/c. I let the dealor install it and jet it. I dont notice any blueing of the heat shield, defently sounds wrong there, but i have a bunch of blueing on the exhuast near the jugs from the lean exhuast from factory. But i do notice a bit of back firing myself at times when i give it some throttle "too quick" it seems.
Ludwig von Buzzthoven
Oct 14, 2016 08:53 AM
irieman64063
Exhaust System Topics
Jul 18, 2007 05:35 PM
BlueRoad
Jun 7, 2007 10:56 AM
Nevar
15
Jan 1, 2007 06:24 PM
spikehyre
Apr 22, 2006 04:05 PM
