DIY Electrical Repair
Old Apr 24, 2009 | 12:39 PM
bdorr67's Avatar
bdorr67
Default DIY Electrical Repair
While riding with a few friends up to Hurricane Ridge, WA I was told that my tail light was out but the brake light worked. No problem, I've got another bulb in my solo bag.
Hurricane Ridge, WA
Changing the bulb out made no difference and discovered that the wire for the tail light came out of the clips and was rubbing against the tire - which burned through the sheathing.
Me looking at the tail light wire damage. Tucked wire back into clips.
Below are some photos of the repair job.
Back on the motorcycle jack.
Tire removed.
Damaged from wire rubbing against tire.
Damage to right tail light electrical wire.
Close-up.
My amateur repair job then wrapped with electrical tape.
Tested it before re-installing.
Bent the clips in to prevent the wire from coming loose again.
Washed the rear wheel while I had it off.
Repair job took me a total of 1.5 hours - which the dealer probably would have charged me for 2 hours for a total of $185 + parts.
Old Apr 24, 2009 | 02:39 PM
NightsterAl's Avatar
NightsterAl
Great looking Nightster Brian and great job documenting all the mods and fixes.
How do you like that S&S AC? I am debating on getting that or the Velocity stack. Really like that light too. Who makes it?
Old Apr 24, 2009 | 03:05 PM
SpursDarkrider's Avatar
SpursDarkrider
Good job, glad it worked out for you.
Old Apr 24, 2009 | 04:36 PM
BucksBike's Avatar
BucksBike
bdorr67, nice job on documenting the repair. You may appreciate this how to on makeing proper crimp terminations in a marine envireonment which has a lot in common with what motorcycle electrics have to deal with. There is more to getting the crimps right and sealed than I thought.
http://www.pbase.com/mainecruising/wire_termination
Old Aug 5, 2016 | 06:01 PM
JoLu's Avatar
JoLu
Stage I
Default 2001 HD Roasd King Police
My HD is having what looks like an electrical problem, the motorcycle mechanic can't seem to find the problem, I was riding on the freeway and it suddenly stopped, lost ALL electrical juice, no lights nothing, then the lights started turning open then the headlight then the starter, it finally started but it was making explosions and missing idle too much. Any ideas?
MedicUSA
Touring Parts
Mar 20, 2017 12:18 PM
Northride
2014-2024 Touring Models
22
Mar 27, 2016 07:04 PM
ggruber
Aug 14, 2015 11:42 AM
Garemlin
Aug 22, 2009 12:48 AM
schumacher
Nov 22, 2008 08:05 PM
