Got a 94 883 sportster that has developed a rocker arm cover oil leak, rear cylinder left hand side.
Can someone provide me the torque specs & tightening sequence?
If you replace the rear gasket I would go ahead and do the front at the same time. I got the same advice from a couple different sources when mine went out last summer.
