Question about belt guards
Old May 12, 2006 | 11:15 AM
TJ461vs's Avatar
TJ461vs
Default Question about belt guards
As anyone changed the upper and lower belt guards on their bike to the chrome ones? What about adding a chrome rear sprocket cover? Are these something that can be done in the garage or does the stealer need to do them. Do you have to remove the rear wheel to do this? According to the catalog, it says easy to install but I am not so sure. Anyhelp on this would be greatly appericated!
Old May 12, 2006 | 11:20 AM
geno3j's Avatar
geno3j
Default RE: Question about belt guards
You can change both in you garage without removing your wheel. Take your time read the instructions very stright forward.
Old May 12, 2006 | 11:43 AM
silverbullet2006's Avatar
silverbullet2006
If that is your bike in the photo why change it you cant see it
Old May 12, 2006 | 09:34 PM
spikehyre's Avatar
spikehyre
I agree that the belt guards are straight forward..take your time. The sprocket cover does require you to remove the rear wheel. If you have a motorcycle jack it too is not bad....shop manual is just the ticket and walks you through setting everything back up....belt tension, alignment, etc....measure you alignment nuts before you loosen everything up. Even with bags it looks good when you are finished.
Old May 13, 2006 | 05:55 AM
TJ461vs's Avatar
TJ461vs
Thanks for the replies. I did the belt guards today, probably took around a hour. Really sets the bike off in that area with the new chrome. I looked at the manual and once I get a bike jack I will do the sprocket cover. I will post a pic of the belt guards after the weekend.
Old May 14, 2006 | 02:46 AM
CRASH's Avatar
CRASH
ORIGINAL: TJ461vs
I just got done this morning doing both of the guards AND the sprocket. And once I had everything I needed (locktite and lithium grease), the sprocket was no problem. Took about an hour, but it is WAY easier with two people...
Iarecobra
May 7, 2017 01:09 AM
Iarecobra
Mar 16, 2017 07:42 PM
bmxatv
Dec 26, 2009 12:29 PM
b_buckets
Mar 24, 2008 09:32 AM
Thongs2U
Feb 18, 2007 12:21 PM
