Posting for a friend
Old May 30, 2009 | 06:36 PM
Schaub85's Avatar
Schaub85
Default Posting for a friend
I posted this in the electrical area too but then thought it might be more suited in here.
So my friend has an 80's sporty. To be short and sweet, it wont hold a charge. He's changed the generator, battery, and checked all the fuses. I dont know a terrible amount about the bike but I was curious if you guys knew of any obvious problems. If he charges the battery, he can ride for about 50 miles without problems. After that if he shuts the bike off, it wont start again since the battery seems to be dead.
I know its not alot of info so if you need to know anything else let me know and I'll get ahold of him.
Old May 30, 2009 | 07:03 PM
RATROD HOG's Avatar
RATROD HOG
take off ground wire at battery and put a test light between ground post and frame and if it lights just a little you have a short some where.
Old May 30, 2009 | 07:06 PM
RATROD HOG's Avatar
RATROD HOG
also with bike running should show aleast 13.5 or more on a volt meter
Old May 31, 2009 | 01:05 AM
hollywood1959's Avatar
hollywood1959
Tell him to check the ground post on the batt. Make sure it's tight. Ratrod is right again, see if you got a drain on the batt. first. With the bike running, take off the positive side and see if it still runs. If it doe's, then you should have a charge. If it die's you got a problem with output. Hope this helps............HOLLYWOOD
harleyfiremedic
Nov 23, 2012 11:23 AM
Rainmakr
Nov 13, 2012 11:54 AM
DiegoKing
May 9, 2009 09:41 PM
tobywan
Mar 21, 2007 09:52 AM
RealDealHog
Jul 18, 2006 02:46 PM
