Can't remove the trans case
Old Jun 1, 2009 | 07:47 AM
drum412's Avatar
drum412
If you've stripped the bolt heads out simply drill them out. Best way is to use a 5/16 drill, then when you drill it, it'll pop the head of the bolts off easily, then you pull the little cover off, and remove the rest of the screw with pliers.
Old Jun 2, 2009 | 03:35 AM
pagey1001's Avatar
pagey1001
Stage IV
No worries, a bit more effort and the cover screwed off. Thanks all the same.
maverick31210
Dec 3, 2015 05:41 PM
fladawg01
Jul 14, 2012 12:00 PM
xcfhxsfxblsx
Dec 22, 2011 06:10 PM
HDF Tech
Sep 14, 2005 09:45 AM
HDF Tech
Electrical/Lighting/Alarm
Aug 2, 2005 07:59 PM
