What's this bolt for and why is it leaking oil?
Old Jun 3, 2009 | 10:32 AM
RATROD HOG's Avatar
RATROD HOG
Originally Posted by OldFenderGuy
Just curious, but why is the bike no longer under warranty?
I noticed that the bike is a 2008 Nightster, and the standard factory warranty is to 2 years, unlimited mileage...
Unless the bike was purchased before June 3, 2007 it still should be covered under warranty, unless I'm missing something.
whats up with warranty ? did you change some stuff that you think voided warrranty?
Old Jun 3, 2009 | 08:08 PM
Dango's Avatar
Dango
Yes...unless it's not true. I remember reading that changing to the Fuel Pak will change warranty. I did the pipes, SE Air and pipes myself.
Old Jun 3, 2009 | 08:10 PM
Dango's Avatar
Dango
Originally Posted by kelton3
It's not a cracked head. It's the rocker gaskets. I had the same thing, replaced the gaskets.
Hey Kelton, I sure hope you're right. Was that bolt loose on yours as well?
Old Jun 3, 2009 | 09:35 PM
nevets61's Avatar
nevets61
Warranty should be valid. I had V&H short shots, fuel pak, ect.. had valve cover gaskets replaced under warranty twice. fuel pak did not cause that problem and won't void warranty. Take it in, get it fixed, no worries..
Old Jun 3, 2009 | 09:44 PM
Dango's Avatar
Dango
All of your comments are making me smile more and more...I just really hope this works out. There are those periodic HD nightmares that appear on here from time to time. Must avoid those!
Thanks again everyone- I'll keep you posted.
Old Jun 3, 2009 | 09:47 PM
highhillbill's Avatar
highhillbill
Yea rocker Gasket above Bolt, Make sure the Rocker top is torqued to Specs FIRST..........my 2 cents of sense
Old Jun 3, 2009 | 11:04 PM
killer scott's Avatar
killer scott
Unless they show that what you have done caused the problem, your warrenty should be ok.
Old Jun 7, 2009 | 10:14 AM
Dango's Avatar
Dango
The good news is that they put new gaskets on and it is still covered under warranty. When I rode it home, however, there was a little oil on the bolt again. Called them up and they said they were unable to steam clean the area 'cause their steamer was down. I'm hoping it is just residule...
harley8963
Engine Mechanical Topics
Jun 30, 2019 01:24 PM
Rusty Axle
Shovelhead
Mar 22, 2018 07:29 PM
Ratwerke
Oct 18, 2015 09:41 AM
Iarecobra
Jan 21, 2015 03:22 PM
SpicOfTheDevil
Nov 13, 2011 07:17 PM
