Sprockets?
Old Jul 9, 2009 | 12:06 AM
09NightsterVB's Avatar
09NightsterVB
Default Sprockets?
Where is a good place to buy or have made a new front sprocket. Keeping the belt drive, but want to add a couple teeth to my front sprocket. Goal is around 3k at 70. Also, how mant teeth come stock in the 1200n's front/ rear???
Old Jul 9, 2009 | 12:56 AM
OldFenderGuy's Avatar
OldFenderGuy
1200 (US Models)
Primary - Engine - 38
Primary - Clutch - 57
Final - Transmission - 29
Final - Rear Wheel - 68
1200 (World Models)
Final - Transmission - 30
Overall Gear Ratios;
1200 (US Models)
1st - 9.454
2nd - 6.500
3rd - 5.040
4th - 4.152
5th - 3.517
1200 (World Models)
1st - 9.139
2nd - 6.283
3rd - 4.872
4th - 4.014
5th - 3.400
Old Jul 9, 2009 | 02:37 AM
XLCR4GM's Avatar
XLCR4GM
I purchased a 30 Tooth Transmission pulley from the local Harley dealer. I think that I read somewhere that the change of 1 tooth is about around 250 RPM or so. The Transmission pulley is cheaper to buy than the rear wheel pulley. You do not need to buy another belt, just loosen the stock one up a bit and it will fit just fine. Any change in either the rear wheel pulley or the transmission pulley will have an affect on the displayed speed on your speedometer and will require the purchase of an electronic unit to recalibrate the speedometer to display the speed that you are actually going. The units that I purchased were about $100.00 each and were from Dakota digital. It just plugged in and it works just like it is advertised to do. I have changed the transmission pulley on two different XL883 Sportsters from the stock 27 Tooth pulley to a 30 Tooth pulley and I am turning at about around 4000 RPM at about around 80 MPH. I can still pull 100 MPH with the new pulley on. I like the extra gas mileage that I get and I love the reduced vibrations at highway speeds (80 – 90). For me it was the way to go. I took one of the two XL883 Sportsters coast to coast (6,000 miles) at the end of May this year and I plan to go again next year with the same bike. Good luck with your project and ride safe.
JimmyL
Jun 1, 2019 03:19 PM
dustyshovel
Apr 3, 2014 05:25 PM
ray2001
Mar 4, 2012 09:04 PM
morrowstang
Feb 28, 2010 12:17 AM
DaytonaJoy
Aug 29, 2009 01:23 AM
