Clutch cable install?
Old Jul 23, 2009 | 08:17 PM
Razorback Rob's Avatar
Razorback Rob
Default Clutch cable install?
Putting my new handlebars on Saturday. Just a couple of questions about the clutch cable. Does it just connect inside the primary or are there any adjustments to be made inside the primary or are all the adjustments made on the outside?
Old Jul 23, 2009 | 08:48 PM
cHarley's Avatar
cHarley
The main/initial clutch adjustment is made inside the derby cover. You have to break the current adjustment setting to remove your old cable. I strongly suggest you get and read the Service Manual before proceeding.
Old Jul 23, 2009 | 09:17 PM
racinorange's Avatar
racinorange
I just finished installing a new cable on my '02...piece of cake with the manual...don't attempt this without it...if you don't do things in a specific order, you can really mess things up...
Old Jul 23, 2009 | 09:53 PM
old skool1983's Avatar
old skool1983
yeah, like others have said, use the manual, make yr primary adjustment at the primary with all the slack ya can in the cable housing, after ya gitter adjusted in the primary (unscrew bearing roller and clutch holder [you'll see what i mean] put new cable in, put back on its holder and screw down till ya feel tenssion then go 1/4 off) pop the derby cover back on and do the fine adjusting in the cable sheith itself. very strait forward....good luck
Allen PapaLanky Eirich
Sep 15, 2018 06:24 PM
sasquatch_38
Ironhead
May 12, 2014 09:18 PM
lostrider06
Jul 4, 2011 09:53 PM
fox4
Jan 9, 2011 07:33 AM
mikeburgess
Aug 26, 2009 12:22 AM
