Ok, i need help...
Old Aug 23, 2009 | 07:07 AM
bmxatv's Avatar
bmxatv
what year is your scoot? 07's did have fuel pump issues.
Old Aug 23, 2009 | 07:18 AM
Junkman67's Avatar
Junkman67
I was told by the dealer to let the "check engine" light go out before starting. not sure why but they said it so I do it. I would suspect you have either a fp problem or as stated some type of sensor for the efi. I had the same type issue years ago on a car I owned and it turned out to be the crank sensor. It my case I pulled it out and it had some corrosion on the pickup I cleaned it off and never had an issue again. I suggest checking codes and go from there.
Old Aug 23, 2009 | 07:56 AM
cHarley's Avatar
cHarley
The dealer gave you good advice:
The bike's ICM/ECM is a computer. Much like your computer at home needs to "boot-up" when you turn it on. The ICM/ECM "computer" on the bike needs time to initialize and gather readings from the bikes various sensors.
bone57
Jun 30, 2013 04:42 PM
billmckeown
Sep 24, 2012 10:23 AM
Baddflhtcu
Jun 2, 2011 10:36 AM
ralogan55
Apr 3, 2010 11:22 AM
retep2281
Aug 15, 2007 11:40 PM
