not charging
Old Sep 6, 2009 | 10:11 AM
nuera2's Avatar
nuera2
2nd Gear
Default not charging
ive looked all over the forums and cant find anything for what im looking for, my problem is i have a 89 sporster and it wont charge it has a brand new stator,voltage regulator and battery if any one can help i would appreciate it cuz its beautiful out thanks
Old Sep 6, 2009 | 10:18 AM
cHarley's Avatar
cHarley
Have you checked the output voltages of the stator and regulator? What's the voltage across the battery with the bike at a fast idle?
Not sure how hard you searched, there was a thread on this here yesterday.
Old Sep 6, 2009 | 10:26 AM
nuera2's Avatar
nuera2
2nd Gear
my father in law has the clymer book for this bike and he did all the test for the charging system and they came back good, when i first got the bike the volt. reg. waqs bad so got a new one still didnt charge so changed stator and put new battery in but still wont start it wqas like around 14 but when you shut it off it will drop to like 12.5 and if you start it and just let it idle it wont go past 12.5 then drop to under 12 when you stop it it
Old Sep 6, 2009 | 11:13 AM
cHarley's Avatar
cHarley
The charging system is not designed to "charge" the battery at idle, it can take 20 - 30 minutes of riding to replace the amount of energy that was drained from the battery each time you start the motor.
A new battery should also be float charged for 24 hours prior to use.
What voltage do you have across the battery with the motor at a FAST (2,000 RPM) idle?
Old Sep 6, 2009 | 01:33 PM
nuera2's Avatar
nuera2
2nd Gear
At fast idle it's in the 13's so I guess everything is working then thanks for the help
98hotrodfatboy
EVO
Jun 25, 2019 11:53 AM
Daddywags
Electrical/Lighting/Alarm
Aug 28, 2018 05:32 AM
adamk
11
Mar 31, 2015 04:22 AM
My2Harleys
Jul 16, 2014 06:34 PM
pyronuc
11
Mar 28, 2014 01:14 PM
