charging problems
Old Oct 14, 2009 | 08:23 PM
survivorslag's Avatar
survivorslag
Stage II
Default charging problems
I have a 2003 XL1200C with charging problems. here are the facts- battery load tests good, batterey cables are new, stator is putting out 30-55 vac depending on engine rpm, vdc output at voltage regulator is 5-6 vdc. I have replaced the voltage regulator twice in the last 3 months. could something be frying the regulator?
Old Oct 15, 2009 | 04:40 PM
WRAITH's Avatar
WRAITH
Check your ground connections. There are 2 ground connection on the engine. One where the starter connects to the primary. The other is above the rear motor mount. Make sure they are clean a tight.
Old Oct 15, 2009 | 08:02 PM
survivorslag
Stage II
Thanks for the input. I'll try it out and let you know how it goes.
Sardo
May 7, 2017 10:42 AM
Dave Bell
Aug 10, 2016 10:20 AM
dunderwood
Jul 30, 2011 09:54 PM
WRAITH
Nov 22, 2010 01:04 PM
pyro
Ironhead
Jun 20, 2007 11:41 AM
