1200c front wheel change?
Old Jul 7, 2006 | 12:03 AM
hdxl1200's Avatar
hdxl1200
Default 1200c front wheel change?
anyone change the front wheel? I have an '05 1200c and would like a wider tire in the front. Is this possible? Any suggestions or help would be appreciated!
Old Jul 7, 2006 | 02:50 AM
deadskull's Avatar
deadskull
Default RE: 1200c front wheel change?
i did. fatboy front wheel, 150 series tire in front to match the rear tire, custom wide glide front end, custom triple trees, more, everything powdercoated black. email me and il shoot ya some pics
stilesbunnybear@yahoo.com
Old Jul 7, 2006 | 10:34 AM
JohnK/Pa's Avatar
JohnK/Pa
If you have a 21" wheel on front, I think they are thinner than if you have a 16". the tire on my 03 with a 16" wheel is 3.5" wide. If yours is 21 you could just get a 16" tire and wheel. My .02
Old Jul 7, 2006 | 06:11 PM
deadskull's Avatar
deadskull
a 16 inch wheel wont fit between the narrowglide forks, it is considerably wider than the 21". it might just squeeze in, but will not work. you absolutely have to change the front end, either an aftermarket WG tree set-up where you swap out your 39 MM forks or go with a complete 41mm WG setup. shoot me an email, and i can give you the breakdown on whats needed.
chris
99dyna
Nov 2, 2020 08:38 PM
tjshireman
Sep 28, 2018 08:07 AM
OIF SuperGlide
Dyna Models
Apr 26, 2013 09:55 AM
wwgg2
Sep 13, 2008 02:04 PM
back again
Mar 15, 2007 12:47 AM
