Roadking shocks installed!!!!
Old Nov 11, 2009 | 12:26 PM
SHOAT's Avatar
SHOAT
YEP. This is definitely going on the to do list! I will need a 1" lowering block because I am a short shat.
Thanks to everyone for all the good info.
Old Nov 11, 2009 | 02:13 PM
Peedib89's Avatar
Peedib89
I have the Street Glide shocks on my nightster. Huge difference in ride. you can find the Street Glide shocks on ebay, ive noticed they tend to be a little more expensive than the RK shocks. I got mine off a forum member here. Check the touring section classified, you may find they there
Old Nov 11, 2009 | 07:36 PM
SHOAT's Avatar
SHOAT
Since you have to shim them out for clearance, do you need longer bolts?
Old Nov 11, 2009 | 08:37 PM
SgtMic's Avatar
SgtMic
Old Nov 11, 2009 | 08:56 PM
will227457's Avatar
will227457
nope same bolts, the "eye" at the top and bottom is fatter on the factory units
Old Nov 11, 2009 | 09:15 PM
mreed's Avatar
mreed
will227457,
Can you post a rear view pic of yours please? I looked at some chrome SG shocks for my XL1200C and they look pretty fat (diameter).
Thanks.
Old Nov 11, 2009 | 11:41 PM
NI-STER's Avatar
NI-STER
I picked up a pair of RK lowering units (12") at a local swap meet for $100, brand new, still in the original packaging, unopened. Still have to install, but can't find the time.
Old Nov 12, 2009 | 11:28 PM
will227457's Avatar
will227457
Originally Posted by mreed
will227457,
Thanks.
this is the side that matters, hard to see but there is a 1in gap between the belt guard and the shock, i don't think they are any fatter than the stock ones...just use washers or spacers on the eyes
schrader valves
Old Nov 14, 2009 | 05:15 PM
jag1886's Avatar
jag1886
Sure hope they work better than they look.
Old Nov 28, 2009 | 02:19 PM
capitalist_slave's Avatar
capitalist_slave
Can't wait to get my RK Shocks installed...
I have my 1.75" 'lowering kit' on order, headed this way, via USPS.
Gonna borrow a jack this week and hopefully have em on next weekend.
Anyone here tie the shocks together to equalize the pressure...?
Have access to Brass and Stainless tubing + all the fittings. Not sure how good i could make it look.
