Good price for a new 1200R?
Old Jul 13, 2006 | 02:15 AM
DougA's Avatar
DougA
Stage II
Default Good price for a new 1200R?
I'm currently deployed and have the option of purchasing an 06 Sportster 1200R though ENCS (Exhance new car sales). With the extended warranty the price for the bike is 10,160. I should be back home next month and I don't have the time or bandwidth to really research prices. Does this sound like a good deal? If I decide to purchase this I need to do it before I return home or am I better off going to a dealership and seeing what kind of deal I can get from them?
Old Jul 13, 2006 | 08:29 AM
Thumper26's Avatar
Thumper26
Default RE: Good price for a new 1200R?
You say, "With the extended warranty...". How long (years) is that for? The bike comes with a 2-year warranty and their 5 or 6 year extended warranty is in the neighborhood of $1,800.00. If it's the 5/6 year warranty you get at the price you quoted, it's not a bad deal.
Thumper26
Old Jul 13, 2006 | 09:57 AM
scrappy883r's Avatar
scrappy883r
sounds good to me here are the specs 1200r
$8,595-9,775
DIMENSIONS U.S. UNITS
Length 90.1 in.
Seat Height
Laden 28.1 in.
Unladen 29.9 in.
Ground Clearance 5.6 in.
Rake Steering Head/Trail 29.6Âş / 4.6 in.
Wheelbase 60.0 in.
Fuel Capacity 3.3 gals.
Oil Capacity 3.6 qts.
Weight
Dry Weight 557.0 lbs.
Running Order 577.0 lbs.
POWERTRAIN
Engine EvolutionÂŽ
Displacement 73.20 in.Âł
Bore x Stroke 3.50 in. x 3.81 in.
Engine Torque 79.0 ft. lbs. @ 3500 rpm
Fuel System Carburetor
Compression Ratio 9.7:1
Miles per Gallon
Carb. 52 hwy / 45 city
ESPFI N/A
Primary Drive Chain
Gear Ratio (overall)
1st 9.315
2nd 6.653
3rd 4.948
4th 4.102
5th 3.517
6th N/A
WHEELS/TIRES
Wheels
Front Silver 13-spoke cast aluminum
Rear Silver 13-spoke cast aluminum
Tire Size
Front 100/90-19 57H
Rear 150/80B16 71H
ELECTRICAL
Instruments Electronic speedometer; odometer; resettable tripmeter; diagnostic readout; tachometer
Indicator Lamps High beam; neutral; low oil pressure; turn signals; engine diagnostics; security system (optional)
CHASSIS
Brakes
Front Dual
Rear Single
Lean Angle (per SAEJ1168) 32Âş / 32Âş
Exhaust System Chrome, staggered shorty duals
COLOR OPTIONS
Vivid black, brilliant silver, black cherry, black pearl, chopper blue, fire red pearl, yellow pearl, mirage orange
OPTIONAL EQUIPMENT
Security system; steel laced wheel
UNIQUE FEATURES
Triple-disc brakes; significantly reduced clutch lever effort; black powder-coated engine and covers with highlighted cylinders and head fins; high-compression, high-flow cylinder heads; performance cams
PRICING
MSRP
Vivid black $8,595
Color $8,815
Two-tone N/A
Custom color N/A
Anodized N/A
Wheel Option $320
Chrome Engine Covers Option N/A
H-DÂŽ Factory Security System $275
ESPFI N/A
California Emissions
Carb. $120
ESPFI N/A
Freight (applies to the 48 contiguous states and Alaska only) $245
Old Jul 23, 2006 | 05:11 AM
DougA's Avatar
DougA
Stage II
Thanks for the info, the extended warranty I can get with it is the 5yr warranty. I think I'll get the ball rolling on this and I should hopefully have a new bike waiting for me when I get home.
HDF Tech
General Topics/Tech Tips
Oct 24, 2005 04:09 PM
HDF Tech
Oct 24, 2005 03:32 PM
HDF Tech
Oct 24, 2005 02:37 PM
HDF Tech
Oct 24, 2005 12:42 PM
HDF Tech
Jun 28, 2005 01:19 AM
