what "wheel" fit a sportster
Old Jan 1, 2010 | 10:40 PM
huff_custom's Avatar
huff_custom
Default what "wheel" fit a sportster
Im just curious what wheels will fit a sportster. Could i fit a 21" x 2.15 wheel thats is made for a 00-06 fxst and a fxdwg 00-05. Can it be modified to fit (spacers or what not). Just curious what would work and if it cant work, why? Thanks, just always wanted to know.
Old Jan 2, 2010 | 07:02 AM
mreed's Avatar
mreed
I'm putting aftermarket wheels from an 08 FXSTB on my 03 XLC and it's definitely not a direct swap. Luckily my front wheel bearing hubs bolt on so I was able to make new ones to fit my stock narrow glide front end and even though that sounds simple it was a bitch to get the wheel centered & the brake rotor properly lined up with the caliper....On the rear I'm making a whole new swing arm & had to cut my frame to spread it.
Old Jan 2, 2010 | 10:12 AM
back again's Avatar
back again
I'll measure my stock 21 from my Train for width but I think it will bolt up.Both 3/4 axles.I had thought of doing that with my Sportster but needed 60 spoke to match the rear I had.G.
Old Jan 2, 2010 | 06:18 PM
jag1886's Avatar
jag1886
The only 21"s that fit are from a Sportster or a FXD or a FXDL , it has to fit a narrow glide single disc front end with a 3/4 bearing.
Old Jan 2, 2010 | 07:48 PM
cHarley's Avatar
cHarley
+1 - But the bearings can be swapped out to whatever size you need if you find a wheel that has different size bearings.
Old Jan 2, 2010 | 08:09 PM
mreed's Avatar
mreed
What about the pre-(pseudo)dual row roller bearing wheels? Will the newer sealed type bearings fit the register?
rightoff1200
Wheels/Tires
Jul 31, 2019 09:58 AM
beary
EVO
Feb 4, 2015 12:45 PM
nc883
Jan 14, 2012 01:34 PM
Badass67stang
Jun 13, 2011 01:31 PM
taggiascoz
Sep 9, 2009 03:22 PM
