the first time I break a belt, I'll convert to chain. I've got 35+ years on chains and only 4 on belts, so you know which way I'll go.
That's great, but 50,000+ miles on a belt with ZERO maintenance or the oil/grease mess is kinda nice. Been there, done that, over 30 years with chains, and I'll never go back. But then I ride 20K+ miles per year and don't need maintenance headaches.
I just did this (on an 883, but it's the same process) it wasn't difficult, but kinda a PIA. Ya gotta take half the bike apart to get to everything. You're not gonna do it in an hour.
Oh, and mine broke just a little under 65,000 miles.
Agree, it takes a while to get it all done. I think if memory serves me correct it took me a little over 2 hours to get it done. That was straight work with no breaks. Not hard, just kinda time consuming.
ok i will let you know how i get on are the pullys expensive if i do need them ??
Yeah, they ain't cheap, but you can find perfect takoffs really cheap....if you need a pulley, check your dealer to see if they have one they swapped for chrome. Also chech the classifieds here.
My 1949 rigid frame chopped Panhead has a chain and 'kicker', and so does my 1981 Shovelhead Dyna LowRider.
In fact the first Harley I owned that didn't have a chain (and kicker) was my 1996 Dyna WideGlide....
To tell you the truth, I don't miss the chain (or kicker) one bit...
The drive chains are a PITA, and like other have said with proper adjustment a rear drive belt should easily last 75,000+ miles. I know guys with over 100,000 miles on their bikes and they are still running the original drive belt.
I went outside one day,getting ready to ride to work. I get the bike out of the garage and started it,warmed it up for about a minute.I jumped on and put it in gear then let out the clutch and it didn't move.I was sitting there going WTF.I got off and looked down and the belt was on the ground. It almost seemed as if someone cut it.It was perfectly cut.
That's exactly how mine broke, except I was in the parking lot of a funeral home.
Just keep up with the number of turns on the belt tightener (wheel alignment). Equal number on each side. I judge the belt tension with my finger. There is a belt tension gauge tool, I've never found it to be necessary.
