Thunder Max on Nightster?
Old Feb 23, 2010 | 01:35 AM
sgtt45's Avatar
sgtt45
Default Thunder Max on Nightster?
I was looking at buying the Thunder Max but was just wondering where it would fit on the Nighster since it is pretty bare bones as is. Has anyone installed one?
Thanks
Old Feb 23, 2010 | 10:29 AM
oinker02's Avatar
oinker02
What year is your Nightster?
On '07-09 it replaces your factory ECM located under seat, but the autotune modules fit directly behind the engine on the vertical frame rails....on 2010's it totally replaces the factory ECU and is hidden in OEM ECU caddy including autotune modules.
Go to Zippers thundermax site and download the install instructions for the diff years....their site can be a little hard to navigate but the info is there for your year bike if you dig.
I've got a Tmax autotune on my '07 Road King and swear by it. I'm fixing to order one for my 2010 Iron now that they finally make one to fit.
PS, the Iron is same as the Nightster and other XL models when it comes to installing the Tmax depending on year. The XR, however is a different beast......so all n all, zippers makes 3 different Tmax's to fit 07-2010 sportys....One fits all 07-09's, one fits only XR's, and the other fits only 2010 XL's including XL1200N and XL883N.
Old Feb 23, 2010 | 07:26 PM
snidermire's Avatar
snidermire
If you're running V&H shortshots you have to modify the pipes in order for the oxygen sensors to fit. They are about a half inch longer then the stock oxygen sensors and wont clear the motor unless you cut out the threaded part that the oxygen sensors screw into, and reweld them at a different angle. I haven't done this yet but apparently any exhaust guy can do this with no problem.
Old Feb 23, 2010 | 10:16 PM
sgtt45's Avatar
sgtt45
Thanks! I will be running the V&H 2-1 Competition pipe.
Old May 24, 2011 | 10:39 PM
capitalist_slave's Avatar
capitalist_slave
Exclamation Zipper Thundermax on Nightster with Short Shots
Bump.
I ordered my Thundermax from the local Indy and have it sitting in my closet as i type.
Working 14hr days/7days a week right now so hadn't had a chance to install it...
Got a pair of plugs for the old bungs and a pair of weld-on 18mm bungs from Drag Specialties waiting to be installed as well. From what i understand the D&D Bobcat pipe i will eventually run has adequate clearance for the longer 'wide-band' O2 sensors the Thundermax comes with... but will have to modify my Short Shots to run what i have now.
Didn't order the Bobcats just yet because i've received so many compliments on the Short Shots (for looks AND sound from Motorcycle guys of all different brand preferences and experience levels).
Will try and make a post, with pics if possible, about my install and results when i get a chance (read: Day Off!).
super48
Oct 7, 2014 10:28 AM
AlexB_HDMX
Apr 16, 2013 12:22 PM
spaniardguy102
Mar 15, 2011 08:55 PM
bdorr67
Mar 22, 2008 04:04 PM
xharleyx
Mar 9, 2008 10:18 PM
