SG air shock installation help
Also, I dont understand the psi level, more psi is a softer ride or harder?
like I wiegh about 180, so should I add 7 psi or 25 psi? I will be going two up now and then, I take it I can change the air when I need to?
and about what size washers will I need? thanks
I did buy a jack, but I am not sure you would really need one. I found a 1500 lb jack at Harbor Freight and Tools for $69.99. It did the trick.
As for PSI, I am currently running 0 PSI in each shock. I bought schrader valves today but I have not gotten a pump yet to fill em up. That being said, the ride with 0 PSI was better than the sh*t shocks that come on my Nightster.
The washers I got were 7/16. I put three on the top and bottom of each shock mount.
Hope this helps.
Well I got my shocks from Frontiercat (Thanks again buddy) 12" chrome RK shocks. I sanded them down, primered then spray with Rustoleum Satin Black hi temp grill paint.
Put them on sunday and started out with 20lbs of air but the ride was pretty much the same so I dropped it to 10lbs.
WOW, what a difference in ride that was, I then dropped to 5 and that is where I feel it is just right for me. The ride is as others have said "night & day" different. The stock shocks on the Iron could feel pretty brutal on some bumps so this is now soo much better. Can't say enough how much I like the ride. Anyone thinking about this mod should do it, it is well worth it.
Details of my swap:
RK 12'' lowered shocks
1 added washer to top bolt
2 washers to bottom bolt -clearance to belt guard about 1/8"
washers added to both left & right side to keep things looking even.
fill valve mounted just ahead seat on frame (seat covers valve so it is not seen unless looking for it)
I am 5'8" 235lbs - air pressure is 5lbs
shocks raised my bike about 3/4" over stock so no obvious difference in hieght of fender. Plus when my fat butt is on the seat who can tell.
Hope this helps.
The psi is pounds per square inch so the higher the # the stiffer the ride is gonna be, I run around 5 to 7 pounds in mine that are installed on a 95’ 883. Even with no air in them they ride just fine as long as you don’t weigh 300 lbs or more. These shocks are a huge improvement over stock and you will enjoy them i am sure. P.M. me if I can be of further assistance.
Also you DO NOT want to use your shop compressor or the gas station air hose to add air to the shocks. The volume of air they hold is so small that a difference of 1-2 lbs is noticable and adding too much air can blow the bladder in the shock (they are NOT rebuildable) So the hand pump is best for this.
Good luck and enjoy your shocks, just about everyone that has made this change likes them. I know I do!
My suggestion - Just bite the bullet, pay the $40-45 bucks for the HD pump and you'll be set. I got mine for $42. The pump has a guage on it, push button air release and it will not lose pressure when unscrewing pump from valve. Cry now (price of pump) and get it over with.
