So I'm trying to replace my starter on my 05 xl1200 sportster i just picked up.
I've removed the clutch cover and all the Allen key bolts around the primary drive housing. the shifter linkage and clutch cable are also all removed.
So my question is, is there any other bolts hiding that I'm unaware about holding the primary drive cover on??
thanks guys i got it. i didn't know that you had to take the little ball bearing piece out where the clutch cable connects. backed that all the way off and the cover popped right off.
