Stage 1 S/E Air Cleaner
Old Mar 30, 2010 | 05:22 AM
WildThang's Avatar
WildThang
Default Stage 1 S/E Air Cleaner
I just read an article in American Iron (April 20101 issue...page 120) on installing the S/E Air cleaner. They stated the ECM didn't need calibration because the O2 sensors will calibrate the ECM within a few minutes...is this true?
Old Mar 30, 2010 | 06:37 AM
WRAITH's Avatar
WRAITH
Yes but only if you replace the a/c (stock pipes ).
Old Mar 30, 2010 | 06:47 AM
fox4's Avatar
fox4
I read that article too, and wonder if they changed the the mufflers from stock or not. If they did not change them from the stock ones it makes sense that no new tune would be needed because the pipes would still be clogging up the system making the a/c flow just like the stock set up.
Old Mar 30, 2010 | 01:11 PM
rich1374670x's Avatar
rich1374670x
They are doing a 4 part build up. Part one was a complete exhaust from v.h. part two was the addition of the a/c. Yes it did state no calibration is needed, for the two mods. Look at the h.p. numbers, rather low if you ask me. I achieved 59.87 h.p with slip ons, a/c and a sert. They had a baseline of 40 h.p. I think they got 6/7 h.p. just from the a/c.
Old Mar 30, 2010 | 04:43 PM
Preto789's Avatar
Preto789
So what they are saying is that with v&h shortshots or whatever and s/e stage 1 I won't need a tune but the hp numbers will prob be lower??
Old Mar 30, 2010 | 07:17 PM
rich1374670x
They said you do not have to do a tune. I feel like the numbers suffer because of this. I have rinehart s/ons and a se ac. And sert. I have more HP. You would think with a whole exhaust you would have more HP.
Old Mar 31, 2010 | 08:08 AM
Preto789's Avatar
Preto789
Maybe v&h went more for looks than performance and the lack of backpressure is hurting hp??
martin1
May 20, 2014 08:42 AM
pettifogger1
Mar 24, 2010 09:56 AM
pmedic433
Jan 21, 2010 06:12 PM
HOGBOB
15
Feb 25, 2008 10:29 AM
fastbagger
Oct 29, 2007 07:00 AM
