Break light does not work
Old Mar 30, 2010 | 09:17 PM
Fsellaro's Avatar
Fsellaro
Stage IV
Default Break light does not work
I have an 03 883C and the break light isn't working i have checked the fuses and the bulb they both look good any sugesstins what could be the problem?
Old Mar 30, 2010 | 09:35 PM
gilmour68's Avatar
gilmour68
Both of my brake switches went bad over that past year ('04 XLC). The rear was a pressure switch that worked off hydraulic pressure. The front is electrical. Actually I went thru 2 rear brake switches in a couple of months. Hope this helps.
Old Mar 30, 2010 | 10:56 PM
Fsellaro's Avatar
Fsellaro
Stage IV
the tail light isn't working either
Old Mar 31, 2010 | 07:14 AM
SportyPig's Avatar
SportyPig
Have you had the switch right switch cover off for any reason? If so, that front brake light switch is very easy to break. If it is broke, both the front and rear brake will not activate the brake light.
Old Mar 31, 2010 | 08:01 AM
Fsellaro's Avatar
Fsellaro
Stage IV
Default taillight problems
no I haven't had that switch cover off
Old Mar 31, 2010 | 08:04 AM
Fsellaro's Avatar
Fsellaro
Stage IV
Default tai light problem
could it be the load limiter for the Led turn signals? installed two years ago
Old Mar 31, 2010 | 04:05 PM
SportyPig's Avatar
SportyPig
Sorry, that was my best suggestion. Time for a test meter.
Old Mar 31, 2010 | 04:28 PM
cHarley's Avatar
cHarley
Does that mean you actually tested them or "looked" at them?
Old Mar 31, 2010 | 04:37 PM
woodworking1's Avatar
woodworking1
have you bottomed out lately? Check the wire under the rear fender. Even if you haven't bottomed out. I had mine come loose and drag the tire.
Old Mar 31, 2010 | 07:45 PM
FlyinJ's Avatar
FlyinJ
pressure switch, went though 2 of the HD ones in a year, swith to the drag one, no problems. 2006 custom
