baffle no baffle
Old Apr 21, 2010 | 09:09 AM
Good Time Gang's Avatar
Good Time Gang
Default baffle no baffle
removed the 4" baffles from my bike. it is louder that is for sure. i think it may be running leaner as well. did not start on the first hit this morning. as a rule of thumb, are there any issues that arise from removing baffles?
Old Apr 21, 2010 | 09:42 AM
Just Dave's Avatar
Just Dave
Read this.http://www.nightrider.com/biketech/exhaust.htm This is what you have done is make Drag pipes and you need to put some Back pressure back in the mix. You will need to change your slow jet to get rid of the starting issues. There is a section on carb tuning on that same site. These are the lollipops ready made to install in your head pipes http://www.bigcitythunder.com/ good explanation of what you have going on there as well. Hope this Helps. Nightrider is an excellent resource on performance and his site is a gold mine of information.
Old Apr 21, 2010 | 05:42 PM
bmxatv's Avatar
bmxatv
I heard that!
Old Apr 22, 2010 | 09:09 AM
XL50#674's Avatar
XL50#674
Yeah you leaned out the mix and will loose power as well. I like the drag pipe sound most of the time, but HD's do run better with some back pressure. I could have took the baffels out of my pipes and had it tuned that way, but I would stillnot have got the low end punch that I have now, plus drag pipes can sounds funny at certin RPM ranges.
Old Apr 23, 2010 | 09:56 AM
Good Time Gang
it started cutting out or missing on me so i put them back in. i will take photos this weekend of the pipes and baffles, but when i went to the big city website, i was amazed at how much they looked alike.
Old Apr 24, 2010 | 09:11 AM
Just Dave's Avatar
Just Dave
Have you got the Screaming Eagle II's slip ons? They might have been switched out the the BCT's already as you saw they make a replacement Baffle for those pipes.
Jimbo45
Aug 4, 2015 02:13 AM
toastman
Aug 21, 2012 02:48 PM
Nate77
Apr 26, 2010 03:19 PM
BIGDADI
Jun 1, 2008 02:34 PM
Racer_Rick
Ironhead
Mar 25, 2008 04:42 AM
