Seeking advice from the Sportster Pros
When Harley introduced the Forty-Eight, I thought to myself, "well this is the bike for me," seeing as how it has the wide rubber up front, regardless of the small tank.
Having never built a bike before, I am not sure I am "seeing the lines" as clearly as I should though.
If I buy a Forty-Eight and raise the tank, will it place even more emphasis on the peanut being so little, or will it actually help the look of the tank giving it the extra height?
Will I get the same "dropped" look in the back with a Forty-Eight as you guys achieve with the Nightsters, or is that all about the suspension mods? See, I'm green, I don't know these things.
Or ... Will my best bet to be ... Go with the Nightster and just put a Dyna fork on it to get the wide tire in the front?
Any input would be greatly appreciated. I'm a rookie and need some guidance.
Which ever way you go there's a lot of guys on here that can give you good tech help when the time comes.
Maybe if you swap the tank with a 3.3 gal peanut...if you lift the tank. Personally, I'm not a huge fan of a tank lift anyway.
Also, look at the fork lowers on the 48 vs. the mid or wide glide front ends. Should you choose to use a fender your options are very limited because of the funky fender mounts (on the 48).
My opinion is that (and this is strictly my OPINION) if you plan on modifying a Sportster the 48 limits quite a bit because of the way the bike is set up from the factory.
Sportsters are super easy to personalize...and very fabricator-friendly. A plain old Sportster is a great blank slate for modifying.
But...if you want to just pick one up & not modify it much the 48 may be a good choice.
