07 fi2000controller settings
Old May 16, 2010 | 12:38 AM
doginzee's Avatar
doginzee
6th Gear
Default 07 fi2000controller settings
hav 07 sportster custom with S E air filter and V + H short shots with cobra fi2000 controller does anyone hav similar system and what settings are you using. posted this already but not sure to the right place. running at 4 3 2 seems ok except at idle. had v + h fuel pak on before but could not get rid of back fire on decel no matter what setting thanx
Old May 16, 2010 | 11:03 AM
Aires59's Avatar
Aires59
I have an 07 roadster, SE filter and V+H shortshots + Fuelpak, had the backfire on decel with the standard baffles but it went away when I changed to quiet baffles. Deeper exhaust note as well.
Old May 16, 2010 | 12:14 PM
longblack1's Avatar
longblack1
You need to turn your first adjustment back to the stock setting. Open the second and third to 3. See how it runs. Then adjust your mid setting a 1/4 turn at a time if needed. You have the first screw turned to 4 which is adding too much fuel at idle. You need more fuel in the middle and top end to adjust for the lean condition of your set up with pipes and a/c.
Old May 16, 2010 | 02:23 PM
RyanC's Avatar
RyanC
My indy installed my fi2000. They had it set 4/6/6. Ran great but sucked the gas down really bad. I now have it set at 3/4/4. Same perfomance as 4/6/6 only my gas mileage went up by 5-10 mpg. Leave that first pot on 3. Adjust the others to your desire. http://cobrausa.com/ has the intstall/settings sheet that you can print out.
Old May 17, 2010 | 03:25 PM
doginzee's Avatar
doginzee
6th Gear
i hav the quite baffles on the bike but no luck. thanx any way.
Old May 17, 2010 | 03:41 PM
doginzee's Avatar
doginzee
6th Gear
i will try that and let u know how it runs. thanx
Old May 17, 2010 | 03:45 PM
doginzee's Avatar
doginzee
6th Gear
when u say 1/4 turn is that a 1/4 turn between numbers 3 and 4 or on the dial 1 to 10 say 2.5 steps as a quarter turn. thanx
Old May 17, 2010 | 04:06 PM
longblack1's Avatar
longblack1
1/4 turn between numbers 3 and 4. In a nut shell,your bike was running lean from the factory,which causes heat and hot oil temps. By adding more air with your air cleaner and pipes to the engine,you have made it leaner. You need to add fuel back to the mid and upper throttle ranges with the Cobra unit. The stock idle setting on the Cobra adds fuel at idle so you really don't need to touch the first setting.
Old May 18, 2010 | 03:01 AM
doginzee's Avatar
doginzee
6th Gear
k will try that
NR5P
Nov 21, 2010 12:15 AM
scotts10rkc
Jul 22, 2010 03:50 PM
rowle
Jan 19, 2010 11:03 AM
Sporty105
Aug 22, 2009 06:54 AM
