HELP! '07 883R not running
Old Jun 5, 2010 | 10:21 AM
Downthehatch's Avatar
Downthehatch
1st Gear
Default HELP! '07 883R not running
Hello all,
I have a 2007 883R with 5600mi. I recently had starting issues. The bike will cycle the fuel pump when the key is in the on position. The bike will turn over but not stay running. It will sputter for a couple of seconds and that is all. This is what I have done so far: cleaned air cleaner, charged battery, changed spark plugs, changed the battery in the key fob security system, checked and cleaned all fuses, and checked/tightened battery cables. One thing that I noticed is that the plugs were covered in carbon after one month. The only thing I have done to the bike one month before this issue is wrap the pipes and install Lick's mufflers with baffles. Could it be a fuel issue??? I have searched the forums for advice but haven't found a solution. Any help will be greatly appreciated!
Old Jun 5, 2010 | 03:36 PM
HOTLAP's Avatar
HOTLAP
Are you getting any trouble codes?
Did you also cheak & clean the relays that are in the fuse box? one of them controlls the fuel pump.
It sounds like it's just running on the pre pressure of the fuel system when it starts but is not getting fresh fuel once it starts, could be that the ECM is not getting input from the crank position sensor.
Old Jun 5, 2010 | 04:01 PM
killer scott's Avatar
killer scott
CHeck the codes... As touched on by the guy above, I would bet its the crank position sensor... I think that 07 had a lot of problems with that.
Crash Davis
Oct 17, 2024 06:50 PM
Andrew Tischer
Apr 18, 2019 07:00 AM
Outamyleague
Nov 4, 2015 11:57 AM
SCEGU
Oct 12, 2015 09:36 PM
live2ride777
Mar 9, 2010 05:53 PM
