sporty
Old Jun 27, 2010 | 10:28 AM
jsmith6752's Avatar
jsmith6752
Default sporty
I have an 05 sporty 1200. I seem to have a low rpm miss. I thought it was a bad chain or belt . Now I am leaning toward the carb. The bike is stock except for a screamin eagle kit. Both spark plugs look great. They show no sign of running rich. Is it worth pulling the carb to check the pilot jet? I also do not get much variation when adjusting the air screw.
Old Jun 28, 2010 | 08:18 AM
Notorious688's Avatar
Notorious688
Yep, sounds like a re-jet at the minimum. Check your pilots.
Old Jun 29, 2010 | 12:43 AM
XLCR4GM's Avatar
XLCR4GM
You do NOT have to pull the carburetor to check or change the jets. Just remove the four screws and take off the bottom of the float bowl. You can get to the jets this way to check the size or to change them out. It almost doesn’t make any sense to have a SE kit on a stock bike. Are you sure the pipes are stock? You can still check out what the jet sizes are just so you can be sure what you are starting out with. Good luck with your issue and ride safe out there!
Dannyj44
Apr 6, 2018 02:50 PM
mrfikser
Apr 5, 2012 11:11 AM
vet767
Mar 21, 2009 10:37 PM
The Baron
Exhaust System Topics
Mar 4, 2008 10:33 PM
NEW2HD
May 9, 2006 12:27 PM
