removing signals HELP!!
Old Jul 5, 2010 | 08:33 PM
br401k's Avatar
br401k
Default removing signals HELP!!
ok so on my iron 2010 883, would it be OK to simply undo the signals, clip the wires, tape em off then hide the wires? would i get any warning lights or screw anything up?
Old Jul 5, 2010 | 08:37 PM
br401k's Avatar
br401k
front signals by the way
Old Jul 5, 2010 | 08:42 PM
HOTLAP's Avatar
HOTLAP
If your leaving the rears in place it may cause the rear signals to flash really quick, remove the front bulbs and try the signals, if the rears flash really fast you will need a load equalizer like the ones available for LED lights.
Old Jul 5, 2010 | 11:38 PM
papadop88's Avatar
papadop88
I removed my fronts a couple months ago. Don't clip the wires in case you want to put them back on or sell them. The connectors are under the tank. Just follow the wires and remove. The rears will blink faster but whatever. You wont get any warning lights.
Old Jul 6, 2010 | 02:04 PM
br401k's Avatar
br401k
thanks. ill work on it once its not 107 degrees outside
Old Jul 6, 2010 | 03:27 PM
onebagger15's Avatar
onebagger15
Post a pic when your done. I'd like to do the same.
roughedges74
May 20, 2014 06:48 AM
Elvira
Feb 5, 2012 12:19 PM
wiliulfo1
Dec 3, 2009 11:23 AM
ottodoggy
Apr 20, 2007 02:43 AM
2Devious
Aug 3, 2006 08:10 PM
