06 1200c Speedo Help
Old Aug 23, 2010 | 10:03 PM
Justinnck1's Avatar
Justinnck1
Default 06 1200c Speedo Help
My 06 Sportster is acting weird. My speedometer lighting stays on after I turn the key off and it stays on until i hit the brakes. I dont remember it doing this. IS it supposed to? if not all help appreciated.
Old Aug 23, 2010 | 11:42 PM
BassCatcher's Avatar
BassCatcher
That light should go off when the key is turned off. Sounds like a short or a poor ground to me. Start with the battery and check all connections and then go from there. If it were me I would take it to a dealer or a good Indy. Electrical troubleshooting can get tricky without the right instruments.
Old Aug 24, 2010 | 12:20 PM
Justinnck1's Avatar
Justinnck1
Ok thanks for the advice. It never did this that I remembered and now i noticed it after I just changed my tires two nights ago.
Old Aug 24, 2010 | 12:27 PM
BassCatcher
There you go...you have a place to start. You must have crimped or pulled loose a wire somewhere in changing those tires.
Good luck.
Old Aug 25, 2010 | 03:47 PM
Justinnck1's Avatar
Justinnck1
Now my speedometer stays on all the time and when I squeeze the brake lever with the key off it turns off for a second and back on.
Old Aug 25, 2010 | 06:13 PM
Justinnck1's Avatar
Justinnck1
Well I now realized that my ignition switch is bad cause I can pull the key out on accessory, but the hd shop can't recognize my vin number
Old Aug 26, 2010 | 06:39 AM
WVHogRider's Avatar
WVHogRider
Uhhhh, that's the way it was designed, and there's nothing wrong with your switch just because you can pull the key out while it's in accessory. Yes, everyone go try your key....It will come out in the accessory position.
I was just going to ask if you're turning your key all the way off when the light stays on or if you're only turning it to accessory and pulling the key.
Old Aug 26, 2010 | 09:43 PM
Justinnck1's Avatar
Justinnck1
I was turning the key all the way back and u can tell there is something messed up in the ignition and I ordered a new switch. By the way there was two other sportster at my local mechanics shop and neither of them could pull the key out in accessory. So now I got a week and 1/2 wait til my new ignition gets here.
Old Aug 26, 2010 | 10:59 PM
wishbone550's Avatar
wishbone550
Mine comes out on accesory. always has too. I have left it on acc before on accident.
Old Aug 27, 2010 | 09:10 AM
Justinnck1's Avatar
Justinnck1
Maybe it depends on model year idk? But mine has these problems and then sometimes I go out and ride it and its doesnt stay on so the switch has got some sort of short in it. I was surprised that the switch was only $70. Does anyone know where the three wires plug in at?
avasquez097
Dec 8, 2018 09:40 PM
EncryptD
Jun 26, 2012 09:01 PM
bikermike41
May 7, 2011 07:30 PM
jk06streetbob
Jan 4, 2011 09:27 PM
ChefE
May 6, 2008 11:17 PM
