cleanning the engine
Or with any good car soap mixed EXACTLY to directions. I like Meguar's NXT soap, and a round parts brush.
I would be a little leery regarding use of MEK, over a period of time, repeated use will take its toll by slowly removing the powder coat. Once upon a time as part of job, I had to remove powder coating from industrial instrument panels in order to refurb. My method was to soak the parts in MEK for 2-3 days. It would flake right off, needing only a little sanding to smooth out the surfaces.
For a really bad stain or tar, maybe MEK once in awhile, and only with a rag blotting and wiping on the localized spot.
Respectfully,
BINGO53
Years ago I worked as a welder at a plastic tank manufacturing plant making the steel frames for the plastic tanks. Fabricators of the plastic tanks used MEK like water to clean the plastic, it stated on the 55gallon tin that it was carcinogenic. As an EMT I use gloves to work with patients and around automotive oils.
I have no specific data to quote, just some life lesson, I apologize if I came across as a know-it-all again I won't work around oils or patients without gloves-it probably won't make much of a diff at my age, peace out, Herb
Potential Chronic Health Effects:
CARCINOGENIC EFFECTS: Not available. MUTAGENIC EFFECTS: Mutagenic for bacteria and/or yeast. TERATOGENIC
EFFECTS: Classified POSSIBLE for human. DEVELOPMENTAL TOXICITY: Not available. The substance may be toxic to
gastrointestinal tract, upper respiratory tract, skin, eyes, central nervous system (CNS). Repeated or prolonged exposure to
the substance can produce target organs damage.
Special Remarks on other Toxic Effects on Humans:
Acute Potential Health Effects: Skin: Causes skin irritation. May be absorbed through the skin. Eyes: Causes eye irritation.
Inhalation: Inhalation of high concentrations may cause central nervous effects characterized by headache, dizziness,
unconsciousness, and coma. Causes respiratory tract irritation and affects the sense organs. May affect the liver and urinary
system. Ingestion: Causes gastrointestinal tract irritation with nausea, vomiting and diarrhea. May affect the liver. Chronic
Potential Health Effects: Chronic inhalation may cause effects similar to those of acute inhalation. Prolonged or repeated skin
contact may cause defatting and dermatitis.
