Heavy Breather Install Help!
Old Oct 14, 2010 | 02:27 PM
RJMerc's Avatar
RJMerc
5th Gear
Default Heavy Breather Install Help!
I'm having a bit of a problem with the final Heavy Breather install steps and was hoping somebody who's done it could help.
In the final step you have to install the adhesive ring to the chrome band clamp cover that covers the base of the filter. No problem there. I then cleaned the base of the filter with a degreaser and tried to get the chrome band clamp to stick to adhere to the filter, but it keeps popping off. The band really isn't all that sticky and I don't see how it's going to hold the cover onto the filter once the bike gets fired up.
Did anyone have to use some other means to hold the band clamp cover onto the filter base? I'm thinking of trying some 3M adhesive, but not sure if I should at this point.
Thanks much.
Old Oct 14, 2010 | 02:51 PM
2011Deluxe's Avatar
2011Deluxe
Mine popped off like that too so I just put it upright with about 20lbs of wieght on it over night and that did the trick. Oh it is double sided adhesive so make sure that you peel off both sides and degrease the mating side of the filter of course.
ib5150
Jan 5, 2020 10:37 PM
ib5150
Mar 20, 2014 10:50 AM
MKZFATBOB
General Topics/Tech Tips
Aug 26, 2013 01:34 PM
118of1050
Apr 14, 2013 08:08 AM
DADAWG
Exhaust System Topics
Jan 7, 2009 05:10 PM
