coil relocation problems
Old Oct 21, 2010 | 08:15 PM
tjyosh's Avatar
tjyosh
Default coil relocation problems
whent the coil relocation , like everyone else but ran in to a white wire that seems that i can't put it underneath the tank cause i to short , any suggestions , thanks really appreciate it
Attached Thumbnails coil relocation problems-dsc05747.jpg   coil relocation problems-dsc05748.jpg
Old Oct 21, 2010 | 09:07 PM
Bobber Jake's Avatar
Bobber Jake
Cut it and soldier a piece in there to make it longer. Wrap it in shrink wrap and it will look like it came that way.
Old Oct 21, 2010 | 09:45 PM
Blaven48's Avatar
Blaven48
Weird I didn't have that trouble with mine when I just did it. What's it going to/from?
Old Oct 21, 2010 | 10:52 PM
tjyosh's Avatar
tjyosh
from back oe the igntion to this connection plug
Old Oct 22, 2010 | 08:54 AM
joebotics's Avatar
joebotics
That is a weird image... are you sure that cable connects between those two points with arrows? the lower/front connector appears to me to be the O2 Sensor connector... which goes back to the fuse / ECM area... it does not connect to anything in that Fuel injection area... I suggest you get all the cables loose and retrace that cable to their real destination and then reroute it under the tank..
Old Oct 23, 2010 | 12:10 AM
tjyosh's Avatar
tjyosh
thanks i guess will have to redo what i idi but probably this picture will make you guys uderstad more , whent ahead and i tink i mess up it goes into the bundle of wires that comes out of the coil
Old Oct 23, 2010 | 12:43 AM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Weird. I did the coil relocation not long ago and I don't remember moving a cable/wire like that.
chgofirefighter
Dec 19, 2013 04:21 PM
Biscuit's Bobber
May 5, 2013 09:29 AM
gant
Aug 21, 2012 01:14 AM
chromedome
Jul 3, 2009 05:44 PM
tnt0303
Jul 26, 2008 02:07 PM
