How hard is it to get to the cams?
Old Nov 3, 2010 | 07:34 PM
woodworking1's Avatar
woodworking1
Default How hard is it to get to the cams?
I have a 99 883c with the 1200 conversion. It was installed by the stealer by the previous owner. I was told that when the conversion was done there were "mid range cams" put in. All other work done on the bike was documented except that. So I am not 100% sure what was done. I am figuring the only way to check is to pull them and measure them. If I am correct in assuming this, how difficult of a task is it? Any input will be greatly appreciated.
Thanks,
John
Old Nov 3, 2010 | 07:39 PM
harleyphoenix's Avatar
harleyphoenix
Couldn't you find out the lift by dropping the upper pushrod cover and measuring the movement of the pushrods?
Old Nov 3, 2010 | 07:50 PM
woodworking1
LIGHTBULB!!! Stock rods = stock cams
Correct me if I'm wrong.
Harleyphoenix-you are on to something. It made me realize that I have stock pushrods, hence no top cover.
I just read in my manual that the stock cams are stamped with a "D" If my above assumption is wrong, then all I have to do is pull the cover and take a look.
Old Nov 4, 2010 | 06:02 AM
DaytonaSportster's Avatar
DaytonaSportster
Most cams will work with "stock" pushrods and there covers.
Just take off the cam cover, and look.
Its what, 6-8 bolts and a new gasket,
Old Nov 4, 2010 | 06:22 AM
xFreebirdx's Avatar
xFreebirdx
+1, but there are exceptions to that. My heads were decked for higher compression so I had to use shorter pushrods.
Old Nov 4, 2010 | 08:45 AM
cHarley's Avatar
cHarley
Be sure and follow the instructions in the Service Manual for removing the cam cover. It's real easy to drag a cam out with the cover, and then you'll have more work than you bargained for.
Old Nov 4, 2010 | 06:16 PM
woodworking1
Thanks for the advise cHarly. I was hoping you would chime in! That's the kinda valuable info I need. What are your thoughts on the stock pushrods with cams? I was told they were SE mid range cams if that makes any difference. I'll will end up removing the cover and putting an eyeball on them if there is a chance they are not stock, I am dying to know!
Thanks,
John
Esco11
Apr 8, 2017 05:17 PM
dvanhorn
Oct 29, 2012 12:29 AM
Superfly3176
Jan 14, 2012 08:20 PM
FatBobber08
Nov 16, 2008 05:09 PM
Islander
Exhaust System Topics
Jun 12, 2006 01:27 PM
