48 pipe question
Old Jan 5, 2011 | 01:17 PM
Heli250's Avatar
Heli250
Stage IV
Default 48 pipe question
Will the Vance & Hines competition series muffler fit the sportster 48 without any mod? Are they pretty straight forward to install? Also I wanted to find out what needs to be done when the pipes and air cleaner are changed from the stock ones. Do I need to get a race tuner? Thanks
Old Jan 5, 2011 | 01:38 PM
Blaven48's Avatar
Blaven48
Yup that muffler will fit. Someone has a picure of it on their bike in the "Let's see your 48's" thread a few pages back. They aren't hard to install at all if you aren't afraid to get your hands dirty with some tools and can follow directions well. But they are pretty straight forward. Some people don't do anything for fuel management when changing the A/C and pipes. I got a fuel pak since I had bad popping on deceleration. But check out x14ied's from nightrider.com. They are cheaper than a tuner and do basically the same thing minus the marginal performance gains. If you do a search a lot of threads will come up with more info.
Old Jan 5, 2011 | 01:49 PM
Heli250's Avatar
Heli250
Stage IV
Thanks for the great info.
Old Jan 5, 2011 | 02:18 PM
Blaven48's Avatar
Blaven48
No problem at all, glad I could help
Old Jan 6, 2011 | 09:13 AM
XL50#674's Avatar
XL50#674
This is good info and like was said the x14ied should be fine, but if you want more power out of your set up look into a SERT or PC III or V. if you are just going to do the slip on's then no fueling is needed. The slip on's are easy to install and ever full pipes are not that bad.
Old Jan 17, 2011 | 06:34 PM
jmr44's Avatar
jmr44
Stage III
Are you interested in selling your stock pipes?
bpd138
2014-2024 Touring Models
19
Oct 20, 2014 08:51 AM
valle
Feb 2, 2014 08:46 AM
bobbys rocker c
Oct 6, 2011 07:47 PM
ROVPLT
Aug 19, 2009 11:28 PM
evil_V
Exhaust System Topics
13
Mar 30, 2008 11:11 AM
