Power increase again
Old Oct 6, 2006 | 04:10 PM
SimonW's Avatar
SimonW
Default Power increase again
Another rejetting issue..
Can I install the Dynojet with Thunderslide without changing the air cleaner?
Can I change the Jet + Air cleaner without changing the exhaust pipes?
Can I get more power only by changing the mufflers?
I'm a bit confused with all the tuning tips...[&:]
Old Oct 6, 2006 | 04:24 PM
tim@tmgdesigns's Avatar
tim@tmgdesigns
Default RE: Power increase again
The power gains are from the engine breathing better. This means getting more fuel and air in and getting rid of the spent gasses sooner. If you only alter one side of the motor, you still havent completed the process to achieve more power. In order to get optimum performance, you need to alter the intake and exaust evenly.
Old Oct 6, 2006 | 04:27 PM
GothMetalGuitarist's Avatar
GothMetalGuitarist
ORIGINAL: SimonW
Sure, but why?
ORIGINAL: SimonW
Yes..and you should.
ORIGINAL: SimonW
Yes and no. Drag pipes (no baffles) no not with out the air cleaner and re-jet, Slip-ons yes, and you should.
The best results is to go for a high flow AC and a high flow Exhaust. Lotsa air in, Lotsa air out. Then with a re-jet and a good tune up you will be a VERY happy HD owner....or at least on your way.
Old Oct 6, 2006 | 04:30 PM
GothMetalGuitarist
ORIGINAL: tim@tmgdesigns
Tim
Not all who wander are lost. (Tolken)
And if you spell Tolkien's name right Gandalf will cast a spell on your Harley and you will get 5 more horsepower!
Old Oct 6, 2006 | 05:01 PM
Thumper26's Avatar
Thumper26
With regards to the "drag pipes": If you install them and open the intake you will realize the power increas at the top end. Low end and mid-range will suffer in power. In what range do YOU do most of your riding? Drag pipes are LOUD but not practical for general riding, unless you're on the strip every weekend. Of course if LOUD is all you want, you want drag pipes...
Old Oct 6, 2006 | 05:53 PM
SimonW's Avatar
SimonW
So... what do you recommend for AC+Jet+Slip-ons? (Sorry for bringing this never ending question up again..)
Does Screamin' Eagle have a homepage where the products are described?
Old Oct 6, 2006 | 06:36 PM
Thumper26's Avatar
Thumper26
The least expensive, and IMHO the most effective, is a free-flow AC (Screaming Eagle, Hyercharger, Big Sucker, Hurricane, S&S Teardrop, etc.), rejet, and after-market slip-ons (SE II, Cycle Shack, etc.). On the exhaust side, if you buy more than slip-ons you're really doing it for looks, not more measureable performance.
Old Oct 6, 2006 | 06:56 PM
SimonW's Avatar
SimonW
Thanks Thumper26, and all the rest also.
ORIGINAL: Thumper26
Old Oct 6, 2006 | 06:59 PM
GothMetalGuitarist
ORIGINAL: Thumper26
Wait a minute....you are say that my throttle has more than 2 positions?!?!? HOLY CRAP it's like a whole new bike!!!
Old Oct 7, 2006 | 02:20 PM
SimonW's Avatar
SimonW
ORIGINAL: GothMetalGuitarist
ORIGINAL: SimonW
Sure, but why?
I want to get rid of the carb farts. Pretty annoying the other day when it farted in front of a Police Car..
Also I want to be able to push the enrichener **** all the way in a bit earlier.. Dunno if I'm just bullsh****ng now...
ORIGINAL: SimonW
ORIGINAL: SimonW
