48 handlebar cable extension kit
Old Feb 9, 2011 | 12:23 PM
vasya100's Avatar
vasya100
6th Gear
Default 48 handlebar cable extension kit
Hi everyone,
Just purchased the Flanders #1 handlebar for my 48. The difference in cable length compared to the stock handlebar seems to be 7 to 7,5 inches, so i don't think the stock cables will be long enough. Will appreciate any ideas on the cable extension kit i could use for this installation.
Thanks!
Old Feb 9, 2011 | 12:44 PM
cpracing519's Avatar
cpracing519
burly makes 12" or longer cable extensions but are expensive. I put 10" Z bars and only had to put a new brake line on.If you need to do your brake cable, buy a "build your own" kit. I got a steal braided kit that you just cut to fit and put the banjo fittings on for $55. Company called Magnum. Got it from my local HD dealership.
Old Feb 9, 2011 | 02:44 PM
vasya100's Avatar
vasya100
6th Gear
Thanks for the tip, I've checked with Magnum site and they seem to have all the cables available. I would prefer to buy the full set of what might be needed just to be on the safe side, since shipping takes at least 3 weeks. Can you advise which cables i might need: brake, clutch and idle, or something else?
Old Feb 9, 2011 | 02:59 PM
cpracing519
It all depends on how tall your bars are. I re-used my stock throttle and clutch cables. I just took off a couple of the cable ties and moved them up closer under the gas tank and had enough wiggle room for turning. The only cable I replaced was my brake line. I ordered a 6ft lenghth with 90 degree fittings. Cut it to 37 inches and everything fit great.
Old Feb 13, 2011 | 10:34 PM
Art Vandelay's Avatar
Art Vandelay
I put 12" mini apes on my 48 and I replaced the clutch cable and the brake line, I also just cut a few tie wraps and was able to keep the stock throttle cables. The dealer sells an extension kit for the control wires, it was only like $35 I think and you get to keep the same color coded wires. A few butt connectors and your golden.
Old Aug 27, 2020 | 01:22 AM
SFedorchak's Avatar
SFedorchak
Stage I
what year is your 48? I’m buying a 2010 and have heard that the wire harness extension is different.
Micheal Chaco
Mar 19, 2017 07:18 AM
guuby
May 30, 2016 09:24 PM
fourH-Ds
Aug 21, 2012 08:49 AM
rhoppe
Sep 13, 2008 10:00 AM
mstakern
Dec 29, 2007 09:16 AM
