Help needed removing neck bearing
Old Mar 12, 2011 | 07:44 PM
trozenhorse's Avatar
trozenhorse
Question Help needed removing neck bearing
Hi everyone, i cant for the life of me get the neck bearing off, it just wont move, tried a few tools, grease, wd40 but just cant figure out how to get it off and the service manual does not give any good info for this. If anyone knows any tricks or advice that would be great. tks
Old Mar 12, 2011 | 08:14 PM
shakrr's Avatar
shakrr
try some pb blaster around the shaft let it soak and try a couple of thin blade stiff putty knifes to pop it off
Old Mar 13, 2011 | 12:08 AM
Mike07FLHTC's Avatar
Mike07FLHTC
I use a hydraulic press.They dont just slide off.
Old Mar 13, 2011 | 06:28 AM
cajun555's Avatar
cajun555
On my 08 sporty the lower bearing just slid off. Just serviced bearings on wifes 01, and lower bearing is a press fit. Manual states if lower bearing needs replacing then cut the cage off, then apply heat to bearing to expand and pry off. Then use a lengh of pipe to install new bearing.
Old Mar 13, 2011 | 06:33 AM
Charley05's Avatar
Charley05
They have to be pressed off, I just took mine to my wifes work and had one of her mechanics do it for me so I could have all my triple trees powdercoated, then had them press it back on!
Old Mar 13, 2011 | 02:51 PM
Aaron48's Avatar
Aaron48
Use the bearing pulled Mike has pictured you will love it it works great.
Wi_Duker
Feb 25, 2016 08:17 AM
cf7go
Mar 19, 2012 03:00 PM
rounder
Dec 30, 2009 10:33 AM
fiveola
Shovelhead
Sep 22, 2008 07:35 PM
monster0826
Jun 5, 2006 02:24 AM
