Speedeometer Connectors
Old Mar 14, 2011 | 07:23 PM
Anthonysdad's Avatar
Anthonysdad
Default Speedeometer Connectors
Does anyone know where I can find the electrical connectors that you crimp onto the wires and then push them into the speedometer connector ... they a samll and skinny. The actual speedometer connector has 12 holes and a few are occumpied by red pins.
Thanks
Old Mar 14, 2011 | 07:41 PM
Gpsjr10's Avatar
Gpsjr10
Are you having a problem with your speedo? Do you need to replace bad pins or something?
Old Mar 14, 2011 | 07:47 PM
CosmoKramer's Avatar
CosmoKramer
You can order them from a local HD. They are actually relatively cheap...believe it or not!
Old Mar 15, 2011 | 07:43 AM
Anthonysdad
Thanks Cosmo, and to Gpsjr 10, I actually cut some of the wires close to the connector and can not put them back together ... live and learn
Old Mar 15, 2011 | 11:17 AM
CosmoKramer
AD, have you tried opening up those pins / sockets that you cut, pull the wire out and then reusing the pins / sockets? I would probably put some solder on them just to make sure the wire stays in place. Just a thought.
Old Mar 15, 2011 | 04:52 PM
Gpsjr10's Avatar
Gpsjr10
I have done this in a pinch, but it is a pain and as the pins are cheap anyway, just buy a few and a few extra, just in case. If you don't have the proper crimping tool, be careful cause the bend and break off easy. I usually just use a set of jewlers needle nosed pliers and put a spot of solder on the wire. Most craft stores carry the pliers.
Old Mar 15, 2011 | 05:50 PM
Anthonysdad
Thanks everyone ... I just went a bought a bunch from HD
biggdadd58
Oct 27, 2018 07:02 PM
rage4order
Aug 16, 2015 09:20 PM
ironhide_uk
Sep 21, 2010 04:30 AM
ZBARK
Apr 13, 2010 06:52 PM
straightshot
Aug 8, 2007 10:18 PM
